Hi all,
I'm ready to try my hand at my first HTPC build. I've read assassin's thread and used renethx guide and they were both incredibly helpful.
I want to use this HTPC to replace my Tivo and be able to watch and record all my Comcast channels, burn and watch blu-ray DVDs & reg. DVDs, watch internet video like Hulu, Netflix, etc., and play some casual/older games.
I wanted to run my list of parts by you guys and have a couple of questions.
The parts I am considering buying are:
CPU - Intel Core i3-2100 Sandy Bridge 3.1GHz 2 x 256KB L2 Cache 3MB L3 Cache LGA 1155 65W Dual-Core Desktop Processor BX80623I32100
MB - GIGABYTE GA-H67MA-UD2H-B3 LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
MEMORY - G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-4GBXM
PSU - SeaSonic S12II 430B 430W ATX12V V2.3/EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply
OPTICAL DRIVE - LG WH10LS30 10X Blu-ray Burner - LightScribe Support - Bulk - OEM
VIDEO CARD - SAPPHIRE 100326L Radeon HD 6670 1GB GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card
HDD - SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
OS - Microsoft Windows 7 Home Premium SP1 64-bit English 1-Pack - OEM
Things I already have:
TUNER CARD - Ceton InfiniTV 4
Small wireless keyboard and mouse
The questions I have are:
1. I can't decide on a case. I'm torn between the black Antec steel fusion with remote, the Silverstone LC17-B, or the Silverstone GD05B, OR anything else you guys would think would fit my components. The only real requirement is that it be no wider than 17.5" or deeper than 15". Height is not a factor.
2. Am I missing anything? I know once I decide on a case, I need a remote and a receiver but is there anything else I am missing?
3. Are all of the things I have picked out going to work well together?
Thanks for your help!
-mrflashman
(sorry I couldn't post links to anything...It seems I need to have a couple posts here first)
-mrflashman
