I have some specific questions about the settings of my HDI Dune Smart B1 (lastest firmware) network player. For your information: I m running my Dune with a JVC RS20 projector.
Video settings:
1. Video Mode:
what do I have to choose here? Do I have to choose Auto or the highest my display can? (so in my case, jvc RS20 this would be 1080p60).
2. Aspect Ratio:
Auto or 16:9?
Framerate:
Auto or 24/50/60?
HDMI Color Depth:
Auto, 8,10 or 12?
HDMI CEC:
Disable or Enable?
Force DVI Output:
Yes or No?
Output Colorspace:
Auto, BT.609, BT.709, RGB-Full or RGB-Limited?
Default Decoder Colorspace:
Auto, BT.601 or BT.709?
Audio Settings:
Dynamic Range Control:
Off, Medium, High or Auto?
Volume Control:
Off, Best Quality or Allow Overload?
General Settings:
Fast Disc Access:
Disable or Enable?
Fast SMB Access:
Disable or Enable?
Blu-Ray Playback Improvements:
Disable or Enable?
Blu-Ray Bitstream Improvements:
Disable or Enable?
I know it s will be some work but is it possible that for the ones that know exactly what all settings DO that you guys give a further explanation of the specific settings I ask about?
Thanks for all help and input!
Greetings.
Video settings:
1. Video Mode:
2. Aspect Ratio:
Auto or 16:9?
Framerate:
Auto or 24/50/60?
HDMI Color Depth:
Auto, 8,10 or 12?
HDMI CEC:
Disable or Enable?
Force DVI Output:
Yes or No?
Output Colorspace:
Audio Settings:
Volume Control:
General Settings:
Fast Disc Access:
Disable or Enable?
Fast SMB Access:
Disable or Enable?
Disable or Enable?
Disable or Enable?
Greetings.
