I have looked high and low for some instructions to setup CIH for 2.35:1 using Zoom .with the AE4000 ... no luck. If anyone can point me in the right direction or describe what you've done that would be great.
My primary questions are around what to expect when zooming to fit the 2.35:1 screen. First I centered for 16:9 and saved that to memory. Then zoomed out. The image does not stay centered, so I presume that I need to adjust the vertical shift. Can someone help me fill in the blanks on how to set this up.
Thanks !!
Thanks !!
