Originally Posted by
readyfor3d
also when i watch football when u see the players run it looks like theres a shadow following them it look like crap what is it and how do u fix it?
Hmm, not sure what could cause shadows, I don't see any type of shadows on anything. I have a cable HD DVR patched to the TV with HDMI cable and sports are crystal clear and smooth on my screen. You're more than welcome to try my settings below and see if you like them. I used the Disney WoW disc to calibrate my brightness, contrast, color, hue, gamma and sharpness (you use the disc to set things by eye against reference patterns, so my settings are subjective). I made minor tweaks after that. BTBuck1 has his settings posted previously to try as well to see if you like them better.
In regards to your "handy cam" look, Are your current settings possibly Motionflow-Standard and Cinemotion-Auto1? Using Motionflow with Auto1 gives the ultra smooth look. If you don't like that at all, you might want to turn these settings off, or play around with different combinations of the two to get to your liking.
Reality Creation is an interesting feature. You will have to piddle around with it to see if you like using it or not. It does seem to have an effect on sharpness in some way, at least to my eyes.
These settings assume you've run initial setup and set to HOME use.
--Scene Select menu--
Cinema
Home menu>Settings>Picture & Display
--Picture Adjustments menu--
Setting Memory: Current Input (Common, if you want them for everything)
Picture Mode: Cinema 1
Backlight: 2
Picture: 96
Brightness: 52
Color: 53
Hue: G1
Color Temperature: Warm 2
Sharpness: 44 (if you run reality creation Off, set to 50)
Noise Reduction: Off
MPEG Noise Reduction: Off
Dot noise reduction: Auto
Reality Creation: Manual (15 for both settings, personal preference)
Smooth Gradation: Medium (I like the effect)
Motionflow: Smooth
CineMotion: Auto 2
-Advanced Settings submenu-
Black Corrector: Off
Adv. Contrast Enhancer: Low
Gamma: 0
LED Dynamic Control: Standard
Auto Light Limiter: Off
Clear White: Off
Live Color: Off
White Balance: (Default - All zeros)
Detail Enhancer: Off
Edge Enhancer: Off
Skin Naturalizer: Off [grayed out]
i/p Conversion Preference: Quality [grayed out]
Ambient Sensor: Off
--Screen menu--
Setting Memory: [any]
Wide Mode: Full
Auto Wide: Off
4:3 Default: Off [grayed out]
Auto Display Area: Off
Display Area: Full Pixel
Screen Position: [grayed out]
Vertical Size: 0 [grayed out]
--Pro Picture Setup menu--
SBM: Off
--Eco menu--
Power Saving: Off
