Originally Posted by
club1820
So what software update would that be? Did he say?
I purchased mine in late November and it did a firmware update soon after. I've had no problems with my set (knock-on-wood) as of yet.
So is the software update issue just for your set or everyone? If just yours, are you supposed to live with a set one firmware behind everyone else? if its everyone, are we then all going to have this issue? What did he say about this?
I had to scratch my head on this one because my set (after he factory reset it) is at the latest version release. He did some bobeldy boop fancy remote commands which brought up the error reporting codes and indeed under the s/w update section there was a foreign number. He cleared it and said there you go, all set.
It's worked fine since.
He would only share the well known factory reset procedure with me. Wouldn't tell me the bobeldy boop commands.
To me it doesn't make sense if I'm at the latest rev after a factory reset and it was supposed to have failed during an update.
He did recommend not selecting auto-update though.
