AVS › AVS Forum › Audio › DIY Speakers and Subs › Lab Gruppen FP14000 clone amplifiers
Lab Gruppen FP14000 clone amplifiers - Page 44
post #1291 of 2957
Originally Posted by speckled hen View Post
sorry... i like to drink and, i want one of these amps to run some p.a. monitors. looks like im gonna have to look elsewhere
Didn't you just say you wanted to pick up the Yorkville Unity's? The ones you linked are the passive version. You don't need external processing. Didn't you also say that you were going to use these in your home with a home theater AVR or stereo processor? Dude, that IS your processor. For subs, there will be a sub-out that will provide the low pass filter and the opposite for your mains.
post #1292 of 2957
ahhh snap! yes the unity's are passive with built in crossovers... for some odd reason somebody made me think these amps could only power subs. im not an expert but, i know if all you have is a low pass filter.... you will destroy a tweet or mid.
post #1293 of 2957
Ummm... yeah. These aren't your garden variety Costco speakers.
post #1294 of 2957
fine with me
That's the spirit!!!
post #1295 of 2957
Welcome to AVS
post #1296 of 2957
Nah, that's a high pass filter you're thinking of.
post #1297 of 2957
I cleaned up my post...
Perspective
post #1298 of 2957
Costco sells the best HT anywhere.....LOL
Not or anyoneSO does anyone know if I NEED to use a 7hz Hpass when using a 10Q for my subs?
I only ask because I thought the 10Q had a 7hz roll off anyways. I know that other parts of the signal chain will probably have roll off also but I am just wondering about these 10Q's. What are your thoughts MK?
post #1299 of 2957
Not has a really low freq hpf... although he wanted to implement it with minidsp and apparently the bi quad filters werent functioning right. I dont know what came of that. I also cant remember why he has a high pass, i think its so his lms ultras dont over exert.
post #1300 of 2957
I thought he used a Hpass at 7hz. When I simulated the 21's with a 7hz Hpass I wasn't missing much verse not having one at all. BUT when having one the subs cant really ever be pushed hard enough by me with 2500 watts.
I will be just getting a pair of 10Q's for my L/R and subs.
post #1301 of 2957
Due to my room gain, I have an 11hz HPF. I'm flat to 8hz, and a few db down at 7hz where it drops off like a rock, as intended. This is to protect my subs from overexcursion. Content below 8hz is very hard to even notice, even at 120+db. All you really notice and hear are the doors slamming in the frames and walls creaking.
Relying on the amp to provide a HPF is not something you should really do. It doesn't need to be stressed down there either.
The MiniDSP EQ adjustments on the 2x8 do not work well down that low, however the crossover functions (highpass) seem fine. They added some features to help with EQing down low also, which I ended up using with success as you can see below. Unfortunately, I'm going to have to re-eq things soon, as I ordered the upgrade for my 5308. I'm looking forward to seeing how XT32 handles things.
post #1302 of 2957
Thanks Not. I was going to buy a 2x4 for the subs and a 2x8 for the mains or a 4x8 if it can be configured to do the same thing.
Either way thanks again.
post #1303 of 2957
I run the 2x8 for subs since it can do 8v balanced, where the 2x4 can only do 2v. Huge difference, as I'd clip going into the minidsp otherwise. This lets me keep a lower noise floor as well.
I'd probably suggest using the 8x8 in your case.
post #1304 of 2957
8x8 it is. Thanks again. I keep looking at your 1U build and think I will do pretty much the same thing you did. Looks awesome and professional. Something to be proud of is what I am hoping for.
post #1305 of 2957
Hah, thanks, mine is pretty ghetto though. I could have made a proper back panel, but I was lazy. Works great though
post #1306 of 2957
First, it very cool Denon supports their statement, legacy products like that. That 5308 is truly a statement piece, and seriously, them offering upgrades, that's just fantastic. With your reference quality LF capability, like you,..I too am quite interested in what the added granularity/control points that accompany Audyssey MultEQ XT32, would flesh out of your system. It'd be interesting to see an un-smoothed, before and after comparo. With the added processing capability, I'd suspect the range between the transition frequency, and the upper end of the subs would benefit to a large degree.
It's my understanding the HT SubEQ technology, is embedded into the XT32 offering. That said, I'm curious how they would implement the additional, discrete "Sub Two" controllable output, into the current back panel I/O's. That second channel of EQ/processing, in both the time and freq domains, can offer up some significant benefits. Certainly, it's not like you need it, but it's there none the less. Sure, there is the rogue unpredictability w/some Audyssey tunings, but w/measurement, that's easily discovered.
Good luck, ... and thanks for supporting this important thread.
post #1307 of 2957
just got 2 emails from johnson today... i think its funny how he says "order one FP14000 to test quality at first". test the amp, if it works great, if it doesnt, i'll send you parts and a schematic. he also referred this site... the thread and all for the price of these amps compared to the original, this is soo worth the gamble.
that Fp1400 is a serious beast! however, i think the FP10000Q is better suited for me. i can power 2 mains, a center, and a bass horn on one amp. thats pretty awesome! i just hope it doesnt spudder and i have to constantly replace parts and stuff.
post #1308 of 2957
Spoke with Johnson via email about why I feel my amp is not putting out as much juice as it should and his suggestion was to keep the gain at 44db's, keep VCL at max, but use the soft VCL setting, anyone tried this and seen a marked improvement?
post #1309 of 2957
What is the problem you are having?
post #1310 of 2957
So...running the one UXL 18 off one channel of the FP14K.
Anyone else have to boost the crap out of the receiver (onkyo 1007 here,) After Audyssey...I went from -10 to +5 on the subwoofer level. I have the gain on the clone at about 3/4 and I think we are about 50% of the driver's potential.
Never had to turn the avr up that far before with the behringer and dayton amps....
post #1311 of 2957
Here are my gain settings:
4311ci: -5
SMS-1: 15
FP14k: a little under 11 o'clock
post #1312 of 2957
I have a Yamaha RX-A3000 with an AS-EQ1. Had the gains maxed on the EPX4000's never came close to the clip lights unitil I had the receiver at +10. My FP14k is around 25% to 30%. The receiver level is set at 0 to +5 depending on source material and mood. Taps the clip lights on bass scenes like WOTW with level at +5 and volume in the -5 range.
post #1313 of 2957
After more experimentation looks like it was more J River than the AVR
post #1314 of 2957
Im clipping the amp with the sub +5 over reference, but listening at -10 master volume and the subs dont seem to be moving near as much as they should be. Im definitely not stressing the drivers and I feel with 4000 watts each should make them almost come out of the boxes. im still tweaking but Johnson suggested going to the soft vcl and I wanted to see if anyone else has seen some improvement when doing this
post #1315 of 2957
@beastaudio could you please let me know your jumper settings on the back when you get a chance?
post #1316 of 2957
Also try bridging the amp on one sub and see what is happening. If the amp clips when bridged there is something wrong for sure.
post #1317 of 2957
Anyone know what exactly the differences are between the hard & soft settings are??
post #1318 of 2957
Pic attached.
Mk, I'm running them 4 ohm stereo right now so rewiring my only other option is 8 ohm mono, which is the same amount of wattage, jut one less speaker wire.
post #1319 of 2957
Why use 195V? I picked what ever was closest to my outlets, do you have 220 V's or something? I have 120 V and picked whatever was closest to that. Mine are also on soft clip but never changed it or clipped to matter.
post #1320 of 2957
Beast when you say the amp is clipping at +5 and -10 master what material are you using? Music? What kind? Those drivers wont ever sound stressed with most music you will melt the coils first same as an LMS. You might get some excursion out of dubstep or whatever.
Have you tried something like XMen 1st class or wotw? If you are running one of those and not getting much excursion then something is wrong. Try couple of demo scenes.
What type of ac line do you have the amp plugged inti Maybe its a 120v 15A that is sagging really bad under load which would limit the power. Just an idea.
