Originally Posted by Jason kiDD
Your settings on your amp are correct for your use...
Stick with the voltage that your amp uses just make sure that its at least 30amp if you plan on running it full out.
Like someone else mentioned the actual plug is more for safety reasons that anything else. And noyts amps use a lower gauge that 10a and he doesnt seem to be having any problems so cant say necessarily that there is an issue there..
Next I would look into making sure you are wiring the speakers correctly. Input signal, and finally any leaks in whatever box the speakers are loaded into..
Will the amp pull 30a with a 15a power cord on the amp? Is that what you are getting at? the rest of the chain is able to give it 30a, the power cord on the FP is really all that is lacking.
speakers are wired correctly as Ive stated ive double checked, holes in the boxes have been sealed up, but there definitely were some there to begin, all should be good now tho...
, tnx for answer.
