Originally Posted by whoaru99
Then there is something wrong with the Sanway or the ratings are bogus etc. The IT8K is ~3dB more than the bridged FB10k, which is twice as much power, but in terms of volume shouldn't be big difference. That's established fact, so something is wrong if there is a big difference between the two.
The -4dB LEDs represent ~1700W so if you're just tickling them you're not even to rated power.
3db is double the excursion.
