Originally Posted by Kalani
You can set the power-on order in the software setup for the Harmony remote. I don't recall where the option is buried, but it's in there somewhere... you can customize which devices turn on in precisely the order you set for that activity.
In the Watch TV activity, find the power on sequence option, and just set TV first, then cable box, then AVR. Although usually (I think) the preferred sequence follows the chain, so TV, then AVR, then cable box, so everything is already synced and ready when the actual source device powers up and starts looking for connections. But if switching the AVR and cable box power-on order works for you, go for it.
Edit: Found it: http://logitech-en-amr.custhelp.com/...wer%20sequence
Problem solved! I turned off Viera Link on the TV (and BRD) and have no problem anymore.
Previously, the issue seemed to be that the last device to handshake with the source took the audio, so I needs turn the tv and source in first, wait for it to finish connecting and then and only then turn on the AVR. The Harmony turned them on in quick succession (switching the order had no observable effect actually), resulting in the TV's handshake **** blocking the AVR, to be crude. Turning off VIERA Link seems to solve it for both devices. Now, to test the Xbox...
I'm loving my harmony 650 btw. Can't believe I waited this long...
