Originally Posted by Afroteddy
The 720 seems to work well with the receiver. The software programmed the codes but didn't assign all the button/commands on the remote. At first I couldn't use up, down, and enter/ok but I went back into the software and assigned the buttons because they were left blank. I'm sure I'll have to fine tune some more later.
yes, the default assignments from the Harmony software are often incorrect (the up/down arrow thing is a notorious issue, I have no f'ing clue why they would do that with the directional arrows instead of assigning them all to menu up/down/left/right like any logical person would do). A lot of people only worry about their Activities and never think to check the button layout in "device mode", which is why I think a lot of people think that commands are missing.
although I just played around with my Harmony account and added an xx12 model and it indeed is missing the "CH LEVEL" button as jconjason remembered. A also added an xx11 model and the CH LEVEL command was there, so it looks like Logitech just screwed that one up. If a few people write or call into their support to complain about the missing command I bet it will reappear (or at least be fixed for xx13 models).
the service centre had said that I could get someone to my place to set it up (as they're assuming that's it's a configuration issue) which will cost me $150 or so.... Do you think this would fall under the warranty if they can't get it working on the basis that it did actually work for the first 6 months and the cause could be as a result of the firmware upgrade? Are there any official notification published anywhere by Denon to advise of any brands/models of tvs that it isn't compatible with?
