So I've been trying to a couple of weeks to download updated firmware for my 2112ci, and I get the Connection failed:25 message. Have tried:
- Microprocessor Reset
- Firmware Reset
- Going directly to the modem (no router)
- Taken to a different ISP (I am on Comcast, tried In Laws AT&T DSL)
According to the firmware log, the update is supposed to fix the "Connection Failed: 25" issue, which basically means if I have this issue, no way to get it fixed other than sending it into the service center. I know if I call Denon, the message will be "don't bother, unless there is a problem". So far, this is the only problem I have (Pandora and Airplay seem to work fine, which is my primary usage).
So should I just disable the update notification and forget about it? Anything else to try, or look for. The update is supposed to fix other network connectivity issues -- although I haven't seen any to date, may just be that I am new to the device...
Thoughts appreciated...
- Firmware Reset
