AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 408
post #12211 of 18069
Originally Posted by Beeron View Post
The AVR is not currently networked. I would just like to be able to use it as in audio portal, playing my itunes library located on a pc in my upstairs office in my basement using the Denon app.
All you need is a Wireless bridge. Pretty much any wireless bridge ever made will do just fine.
post #12212 of 18069
As I understand it you can do that with the AX but not using the denon remote app. You would need to use the app indicated on the AX page (I have not researched further, though). The AX will do this and be a wireless bridge at the same time apparantly as indicated by jonnythan above (will it do both at the same time? I'm not sure).* A wireless bridge will only give you network access to your receiver, which you want! You paid for it in the receiver, use it.. If you get a wireless bridge but not the AX you will be able to control the Denon using your PC and a smartphone with the app. Denon has the apple app now and will be releasing the android app in the next month or so according to jdsmoothie's post in another thread.
For me, and maybe just me, the AX is a waste of money because you can accomplish basically the same thing but spend less money with a wireless bridge.
*EDIT: per subsequent post by batpig it is confirmed that the AX cannot do both at the same time.
post #12213 of 18069
No audio cables or anything else? Just the ethernet cable from the "bridge" to the AVR, correct?
post #12214 of 18069
Yup, that's it.
post #12215 of 18069
All the cables needed come with the product I linked that is on sale at newegg until Sunday.
post #12216 of 18069
IMHO, apple is great at marketing and making money as well as providing fine user-friendly product but there always seems to be another lesser-known product available that will do the same thing for less money. Sometimes it might not be as slick but will cost you less.
post #12217 of 18069
Yeah, that's exactly why I was considering the Airport. It's very minimal in size and will be completely hidden...jack plugged into wall directly behind tv with one ethernet cable connecting the two..
Thanks for the other link...I'm considering it...would have to find the right place to put it since it is "clunkier".
post #12218 of 18069
This could be a bit of a noob question, so forgive me
(background)
I've got a 2112ci. Using two Energy towers as my fronts and bose satellites as my surrounds (came with the house, will swap out later). I'll be buying a center soon (trying to find a suitable shelf to stick it on above my tv) and a surround later.
I've got a comcast cable box, but a non HDMI model. I'm sending audio to the AVR via old school RCA cables (red/white). I can't find any options to output any kind of 5.1 signal in the cable box menu. only options i see are Mono, Stereo and matrix . I only get sound from my fronts
Is there anyway i can get the AVR to do something with the signal so that it outputs some kind of surround sound signal so that it also uses the rear surrounds?
Or do i need to use a digital optical cable for audio for this to work?
post #12219 of 18069
An analog cable only passes 1 channel, so the red/white cables can pass two channels (1+1=2) and that's why STEREO is your only choice from the cable box. However, you can use DD PLII on the AVR (Press Movie button first) to simulate 5.1 from the stereo 2.0 signal.
post #12220 of 18069
Here's what I'm looking to do in some more detail:
I have a computer upstairs in my office running Itunes. My home theater area is in my basement with the Denon 2112. I would like to be able to play my office pc Itunes library in my basement, and be able to use the Denon app (whether it be on a droid or iphone) to control this music.
Ah, but here's where it get's interesting and why adding the Airport Express might be the better option ...
Do you already have nice stereo speakers in your office or are you just using small computer speakers connected to the PC? If the latter and you want better audio quality in your office as well, you could use a set of nice bookshelf speakers in your office and set them up as Zone 2 speakers connected to the AVR so you could play audio to them while the home theater is playing another source. However, using the on board Airplay feature of the AVR this would not be possible, rather if you wanted the Airplay audio to the office, it would also have to be selected in the home theater as well ... whereas, with the Airport Express you could listen to the Airplay audio independently in the office while another source plays in the home theater (eg. Blu Ray movie). Something to consider.
post #12221 of 18069
Does anyone have a UVerse remote code for the Denon 1912 that will power on, power off (put in standby) and allow menu functions, input control, etc?
post #12222 of 18069
I have mine mounted to the wall with double-sided tape. It's rather small and lightweight.
post #12223 of 18069
could i use a digital optical cable for true 5.1 output?
post #12224 of 18069
(background)
As explained, analog red/white audio is 2-channel only. Your cable box should have a digital audio output. Use that instead.
post #12225 of 18069
Yes, optical or digital coax will get you DD 5.1 from the HD channels that support it and would be the better connection over the RCA cables.
post #12226 of 18069
I have tried searching, but didn't find anything. I vaguely thought during setup there was an option to have the volume increase in 1.0 increments rather than 0.5 increments, but cannot seem to find where I can change this setting. Any help appreciated!
post #12227 of 18069
a couple of things:
1. "slick and easy" is worth money, period. Some may not be willing to pay for it (especially if you are technical enough to deal with a less slick solution) but many are. So the extra cost is justifiable.
2. the idea that you can "do the same thing cheaper" is true if you are only talking about the wifi bridge functionality, but the AX can do other stuff too. For example, you can use it directly as an AirPlay node (what I and Chris originally thought that Beeron wanted) and beam music directly to an AX controlled by the Remote app on your iPhone, iPad, etc. So for somebody like Chris who has all his music in iTunes and has plenty of iThings to control stuff, he can put an AX anywhere in the house he wants music delivered and there it is. You can take your iPhone or iPad and determine what song to play and which room of the house it goes to, and it's all (there it is again) slick and integrates perfectly.
post #12228 of 18069
It is pretty compact but it actually has antennae which should give it better range as range is direct function of antenna length.
post #12229 of 18069
can't be done, sorry!
post #12230 of 18069
Too funny ... most owners complain the remote increases volume too quickly and you want it to increase even faster.
post #12231 of 18069
Originally Posted by batpig View Post
a couple of things:
Okay. The origial post on this did mention connecting the Denon to the AX using ethernet patch cable so I immediatelly read wireless bridge because I think about it that way coming from the HTPC / PC world..
The squeezbox does the same thing as far as music streaming goes as the AX but of course costs at least as much if not more..
jd said basically the same thing about airplay with additional information about using Zone 2 with it but I had a little trouble following his post. Has this been covered previously? Maybe I should check the FAQ. The zone 2 use sounds intreging to me.
post #12232 of 18069
there is still a bit of confusion here:
the first thing to understand is that BOTH your receiver AND the Airport Express can be used for AirPlay. You can stream AirPlay wirelessly through an AX (that's what I meant by "audio portal") or, if your receiver is networked, you can stream audio through AirPlay directly to the receiver. That's why it was important to understand if your receiver was already networked or not. If the receiver was already networked then the AX wouldn't even be necessary, because AirPlay is already built into the AVR.
The thing with the AX is that you have to choose one of the "modes", you can't simultaneously use it as a WiFi bridge (internet portal) and also as an audio portal. So think of it as three options:
Option 1: Use an AX as an "audio portal" only. The AirPlay will stream directly to the AX, and you will output the audio to the receiver via an audio cable (NOT an ethernet cable). This has a disadvantage in that your receiver is STILL not networked, so you can't use any of the other network features built into the AVR.
Option 2: Use the AX as an internet bridge, in which case you are connecting it to the receiver with an ethernet cable. Now, your receiver is fully networked, and the AX is serving as an "internal portal" not an "audio portal", as the audio will stream directly to the receiver. The AX is functioning purely as a means to get internet to the receiver (by converting the wifi signal into an ethernet connection). But now you can use all the internet features of the receiver (not just AirPlay but control via smartphone app or web browser, Pandora streaming, firmware updates, etc).
Option 3: What Sammy and Jonny are suggesting is do the same thing as Option 2, but because you are just using the AX as a bridge, you can get a cheaper bridge that isn't an Apple product. So think of it as Option 2 but cheaper....
post #12233 of 18069
One thing I should add is I don't use iTunes so would the Airport Express even work for me in a Zone 2 solution?
post #12234 of 18069
the streaming for an AX is via AirPlay. If you aren't using iTunes, you can't use AirPlay (unless there is some hack out there). There are plenty of other streaming solutions that support DLNA (squeezebox etc).
Note however that the receiver can already stream audio independently to Zone 2. The "solution" might not even be necessary
post #12235 of 18069
Okay. There's a wireless speaker zone 2 solution that jd pointed me too yesterday that probably will be better anyhow because this will most likely be outside on the patio.
For those that use iTunes the airplay / airport express seem like a good idea.
post #12236 of 18069
^^ Perfect answer that covers all the scenarios. Pretty sure the AVR should be networked and now there's two ways to do it.
post #12237 of 18069
Thanks...this pretty much clears up what everyone was saying, and seems to back my original thinking and initially the reason I was looking at the Airport X....with option 2, I can stream my itunes music and use the Denon app with only the ethernet cable used as a connection from the AX to the AVR.
Seems that the only reason you'd go with option 1 using an audio cable is if you didn't have a network capable AVR.
post #12238 of 18069
When you use option #1, you'll likely have far fewer audio dropouts as the audio is streaming directly to the AX, while in option #2, the audio is streaming to the wireless router, then to the AX bridge. So start with option #2 and go to option #1 if the AVR gives to many "Buffering" messages.
post #12239 of 18069
Okay. Option two precludes using the airplay using audio cables and removes $70 from your wallet to do nothing more than option 3. The choice is yours.
post #12240 of 18069
Great, will try that. Thanks again to everyone for their input on this.
