Originally Posted by tvuong
All you need to do is to connect the HK IR to the back of your 2312 and tape the eye emitters to other devices. The eye emitter is for device that does not have the remote in input. Your 2312 has this which allows a cleaner look connection. If your HK IR still works, use it, why buy the Harmony extender? The Next Generation product from Amazon is an excellent product and cheaper than the Harmony if you should need one.
Thanks! Right now I have an eye taped to front of AVR 635 (don't know what happened to cable to connect to IR in on back of unit). Question - the Logitech unit does not have eyes that can be taped to the front of components, but 'blasters' that sit in front of components. Will the blasters work as well as the eyes that are stuck to the front of units?
