AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 416
post #12451 of 17925
Thank you for the quick response. As far as checking the speakers. I checked them with an ohm meter. I know that wont tell me everything but I was able to tell they weren't "shorted" .. I also used the Ohm meter to check the cables. Now, mind you, this was with my older Polk front speakers. I have since bought new Klipsch front's and still the same problem. I have not eliminated the other three yet so like you suggested, I will hook the front's up with the new 2312 and see how that goes? Then hook up the other three, one at a time? I have no "in wall" wiring, My wires are all new and exposed. I have double and tripple checked the polarity and to make sure no wire is touching anything but the binding post's.
post #12452 of 17925
you have a short somewhere...
and it's unlikely to be in multiple consecutive receivers...
re-check everything again, and follow the test procedure jd suggested... i KNOW you've checked everything, but it has happened on occasion that a "second check" finds something that was missed...
post #12453 of 17925
Originally Posted by asphaltmodifed View Post
I had it for 3 weeks and it shut down while watching T.V.
it's working fine for 3 weeks, then the same thing. It went into over-protect, red flashing light and shut down.
Everything sounds great. I turn up the volume to a - 4 DB and 15 minutes later, over-protect, Amp shut's down. I feel the amp, it is VERY hot.
Noob question to the group, I always thought a short would cause the receiver to go into protect mode immediately. Could someone explain how a short would cause an AVR to shut down after a while? Is the idea that something isn't permanently shorted but just kinda loose and randomly shorting occasionaly?
post #12454 of 17925
How do the Dac's,l Dsp boards, and analog input stages compare between the 3312 and the 4311? I am just curious. Thinking about picking up a 3312 but might wait a few months and save up for the 4311.
Also, a very important question, what does the 3312 go for these days with the 3313 almost ready to be rolled out? What about a used price on the 3312?
post #12455 of 17925
in all likelihood, indistinguishable in a controlled test...
sorry, this isn't a pricing thread, but if you pick up the phone and "call" the usual suspects, you can get the price...
post #12456 of 17925
Thanks Chris. I will do that. While waiting on the 2312 would ordering and installing banana plugs be beneficial? If so, Any recommendations, where and what to get for Monster cable, 16 Gauge?
The first receiver, the 891, never had this issue. It was never played loud or got hot when it shut down. In fact, when it shut down it wouldn't re-start. It would just flash red. The last 2 receivers, both 981's get extremely hot and shut down but re-start after a minute of cooling down. Thanks for the help guy's.
post #12457 of 17925
In the case of a single wire strand from one post touching another post, increasing the volume beyond a certain point will provide enough current to trip the protection mode of the AVR.
post #12458 of 17925
Ahh, I got ya. Makes sense. Thanks jd.
post #12459 of 17925
As I was replacing my receiver last weekend, I praised that day years ago that I took the time to hook up banana plugs. Literally - I thanked myself out loud.
Someday, down the road, you'll be glad you did.
post #12460 of 17925
You don't need to waste your money on expensive Monster cables. Forum sponsor Monoprice is a good source for speaker wire and banana plugs.
post #12461 of 17925
Originally Posted by Sammy2 View Post
Not excessivelly hot. I do need to ventilate the cabinet better. I have two 12volt,120mm nexus realsilent fans to install. It didn't seem any hotter than. Normal. I was just runninig it through the paces for the first time with the race scene in Phantom Menace while trying out new video (MadVR) renderers in my Htpc.. I usually don't play it anywhere near that loud.
Just curious, how do you plan to power the 12V, 120mm fans??
post #12462 of 17925
During the first hour of last nights House finale entitled "Swan Song" the audio through my 1912 (Audussey set) was beyound chaotic. Dialogue was too low, music too loud and overpowering. Surprisingly, commericals were perfect. This drove me crazy! My wife theorized while this special had horrid Dolby Digital the actual final eposoide would be just fine. She was absolutely correct!
The thing that bothers me so much is if we used just our 2012 Sony HX750's crappy speakers the audio would be stable. Technology sure sucks every now and again.
post #12463 of 17925
installing banana plugs can't hurt, but they are far from "necessary"... personally i like the gls safe connect ones, they are inexpensive in bulk...
don't buy monster cable... it's grossly overpriced... go to your local big box store and buy 14 gauge zip cord (or lamp cord, it doesn't matter)...
post #12464 of 17925
With a 12V wall wart I have from some sort of electronics device that has outlived it's usefullness. I might even put a thermistor in the circuit so they only come on when the temp in the cabinet rises above 85F or something.
post #12465 of 17925
It sounded perfect to me on the 2312ci. Have you run Audyssey yet?
post #12466 of 17925
Yes I have.
post #12467 of 17925
the components are basically the same. But that's not the reason to step up to the 4311 -- you do it for the better processing: MultEQ XT32, SubEQ HT, 11 ch capability, etc.
post #12468 of 17925
Maybe boost your center channel a few dB?
Also, do you have DoblyDigital PLIIx set to matrix out the sound?
post #12469 of 17925
Boosting the center helped with the dialog a bit but the music was still far too loud. I do not understand what you mean about "matrix out the sound". Both broadcasts were in DD 5.1.
post #12470 of 17925
I didn't notice any issues watching the House finale last night. I have a 2310ci and was getting Dolby Digital over digital coax from my HD cable box. Same settings I use for all cable TV watching -- Dyn Vol set to EVENING with the offset at 15dB.
post #12471 of 17925
Dyn Vol set to also set to evening. I reset it to day and got little to no improvement. I have not adjusted the offset. Isn't that setting for equalizing TV and BD audio?
post #12472 of 17925
See previous posts. The problem is with the Iphone series (4/4S) using Airplay with the 2312Ci. If you simply turn off the amp or pause the app( Sirius, Rhapsody, Pandora, etc ), the next time you connect you will get the Airplay Speaker not Available error. I spoke with Denon tech. The solution, to prevent getting the Airplay Speaker Not Available when you re-connect is to make sure you uncheck the Airplay icon on your iphone then turn off the amplifier. It will reconnect with Airplay the next time without a problem.
post #12473 of 17925
I usually just by bypass the Wizard and do the setup with manual measurement of the speaker distances. Had a rainy day, so I dragged out the microphone and did the guided Audyssey, 8 positions.( would you believe the phone rang right in the middle of one of the measurements!!). I have to say I am really impressed. It really works and creates a very nice listening experience. Realism is the word that comes to mind. It presents the sound quite nicely. I did go back in and change the speakers to small and raised the crossover from 40 to 80. I have 2 powered sub-woofers and I like to have a little more bass in my music. I am using it primarily for music right now. Now I have to figure out how to save the settings to a file. I'll dig a little.
post #12474 of 17925
The way I understand, Audyssey's dynamic volume and EQ adjust for the volume level of the receiver, not the actual level of the source material. That's why the offset setting exists - movies are mixed for a different level than TV. If the offset is wrong, the frequency response will be dynamically adjusted for a different volume setting.
post #12475 of 17925
I hate to seem so dense yet how do I determine were to set the offset?
post #12476 of 17925
For TV viewing it should be I think 10. At 0 I think you won't get enough correction in TV and at 10 you'll get too much in movies.
Read this: https://audyssey.zendesk.com/entries...eference-level
post #12477 of 17925
Thanks. Based on your statement how does one handle watching TV movies? Go zeo out the reference level?
post #12478 of 17925
I dunno, I think it depends on how the movie is mixed and broadcast. I'd probably keep it at 10 unless either:
1) I was watching a feature film on a movie network like HBO, or
2) I thought that whatever I was watching had too little bass and surround volume, in which case dropping the offset to 0 should help.
post #12479 of 17925
#2 is the other way around... if surrounds/bass too much, INCREASE the rlo...
post #12480 of 17925
Ah, you're right. It can get confusing.
