Hello All,
I am a new member but old reader of AVS. I recently bought a 3312ci and have worked through most of my issues thanks to this thread. One issue left is the loss of my GUI when I select another video source for anything NET/USB related. Works fine for the tuner part.
I SENT THIS RESPONSE TO DENON SUPPORT BELOW:
-Quoted from avsforum.com
"7. Sometimes the GUI will not appear when the NET/USB source is selected on the networking models.
1/23/12: Denon's response: Although originally reported as a hardware issue, this issue is not wide spread and is being handled on a case by case basis by Denon service. Several work arounds include setting HDMI Control to OFF or unplugging the AVR for 10 minutes, or better yet, unplugging it overnight (neither of which should reset any settings). Yet, another solution has been to turn on the AVR first, followed by the TV. "
I have done all of this and I still have no video with any NET/USB options. It does work with Radio/internet Radio. Is there any resolution to this problem?-
I GOT THIS RESPONSE BACK FROM DENON:
-Hello Henry,
Just to clarify, whoever posted that response on AVS is not a Denon employee nor affiliated with Denon Electronics is any way.
That being said, we have not been able to duplicate a NET/USB GUI issue here in our test lab with any of our models.
-What make and model TV are you using?
-How long is the HDMI run from the 3312 to the TV?
-Are you using Cat 5 / Cat 6 baluns?
-Are the 3312 and TV running the latest firmware?
-Can you output the 3312's GUI (setup) menu consistently?
You also commented that you have OSD info when playing back the Tuner Internet Radio. The OSD info generated by those two sources is 480i, which is the same as the NET/USB GUI. Have you tried disconnecting the Ethernet connection and then selecting NET/USB on the 3312 to see if you get different results?
Thank you,
Technical Support / Custom Install
D&M Holdings NA -
I have a feeling I may get no were with this. What can I do to have some success with this?
I had the GUI for about a second when I first selected a different video source but it has not worked since. Works fine when I have just the "SOURCE" selected.
-Hello Henry,
Thank you,
D&M Holdings NA -
