Originally Posted by zshortstop
Would just like to know the best connections with some new equipment. Panasonic ST50, Denon 1712 and Panny Blue Ray 110.
I just want to play BluRay/DVD through Denon with denon controlling audio format. Sound from TV going through Denon when using watching HBO, Pandora and streaming/watching Netflix and some occasional TV programming.
Am running an HDMI from the 110 to Denon(BD). I then to run HDMI from Denon(ARC) to the ST50 HDMI 2(ARC) and turn Denon on HDMI on? I also have optical going from Denon to TV. Have also ran Denon HDMI ARC to TV HDMI 3 with HDMI control set to off on Denon.
What should my input assign look like if I use this set-up? If I am mis-assigning my present assignment could it be a cause of my problem?
My concern is since adding the new TV I get quick intervals of loss of sound and loss of picture (or rainbow pixilization) at the beginning of rented DVD/BR's(redbox and netfix) with sometime complete loss of signal for a few seconds(check connection screen notice) that comes and goes. It seems to stop after the first several minutes of the movie and runs fine after that.. I have checked and changed out HDMI cables and used both HDMI 2 and 3 on the ST50 with similar results. I had the same setup with a Samsung DLP prior that didn't have an ARC slot and used a regular HDMI slot on the TV and the optical cable with no problem. Is there something in my connection set-up or settings in any/all three pieces of equipment that I am missing or doing wrong? A couple of personal DVDs don't seem to have this problem.
As Seldon suggests, the audio drop outs are more likely due to poor quality rental discs. To get the ARC feature to work you'll need to set VieraLink to ON and set audio to external speakers on the ST50 as well as setting HDMI Control to ON on the 1712. If this works as you like, you can pull the optical cable cable. Why do you have the 2nd HDMI cable from the AVR to the TV?
