Originally Posted by jcahill79
Do you have another mic you can use? When i first used the mic that came with my 3312 it did the exact same thing. I then switched to the same mic that came with my 1910 and the results were vastly different. In fact I went back and re-ran it again with the new mic and Audyssey could not even complete the measurements. It kept choking out on the 2nd position.
Unfortunately no, I don't have another Denon mic that I can use. I'm hoping that's not the problem. My room is a bit problematic (long and narrow, with the sound system/display on one long wall and the seating position on the other, both at slight angles to the walls) but isn't that what Audyssey is designed to handle? Room correction? I've run Auto Setup 3 times and this is getting very frustrating. I'm tempted to just forgo Audyssey completely and manually configure with my SPL meter, but I'd *like* to use this feature of the 3312. Now, to just get it working.
Any thoughts?
