Originally Posted by jdsmoothie
Correct. Remember when we started this journey that you were having issues getting the HDMI Standby pass through feature to work correctly (which does happen with some TVs) so the suggested configuration to make it easier on your wife was to connect the cable box (HDMI) directly to the TV so she wouldn't have to turn on the AVR and then also connect the cable box (optical) to the AVR (optical) to provide DD 5.1 surround audio when you wanted to use the surround speakers. You would then connect TV (optical) to the AVR to pass the TV's smart app audio back to the AVR (if the ARC feature is otherwise not a viable solution). As there's only one optical input on the AVR, connect the cable box(optical) and the TV(optical) to a 3:1 optical switch and then connect the output of that switch to the AVR (optical).
Hey JD...I set the system up as suggested, with the optical switcher. But I'm only getting Pro Logic when i watch cable, and I know some of the movies etc are passing Dolby Digital.
Is there something in the avr settings I need to change, like turning off the ARC/pass through?
