(Continuing from posts 16812, 16830, 16856)
I'm losing sleep...losing weight. My hair is falling out...well, not really this bad, but this is very frustrating me to the point of second guessing this purchase.
I've tried yet again last night and this morning...multiple Network resets, unplugging all HDMI connections (except the OUT to TV so I can see the GUI), confirming hard line connection plugged directly into modem/router, placing this device in my router's DMZ, switching to Tuner source, using the "Start" option instead of "Check for Update", confirming network connection by playing Internet radio, trying with a Static IP and also attempts with DHCP on....this is getting to be nonsense. The results remain to be either "Connection Failed 25" or "Authenticating" for infinity.
Just for confirmation, I have gone through the process of checking for a firmware update, and it tells me one is available and will take an estimated 32 minutes to complete.
I thought I should also mention that I had a continuous ping going on the devices IP. I noticed that after a couple minutes of "Authenticating" after pressing the "Start" option, I noticed that pings started to fail for a few cycles, then resumed to being successful.
I don't what else there is I can try. I'll try to do an afternoon and 4PM time-frame for my next attempts. I cannot understand why this product will be on the market and advertise the ability to perform firmware updates when SOOOooooooo many users have issues with firmware updates. I think that it is ridiculous that I may have to haul this or send it to some service center to perform the update for me when it is a built in feature that should be out of the box able to do this.
PLEASE: any more suggestions?
Edited by Dru the Fu - 1/17/13 at 4:01pm
Originally Posted by jonasro
Dru - I had a similar issue and tried most of what you've detailed... What I didn't notice in your list was actually making a direct connection from the receiver to your modem, either by hard wire or putting the receiver's IP address in your router's DMZ.
The sequence that worked for me was: 1) put receiver's IP in router DMZ, 2) make sure you're hard-wired from receiver to router/modem, 3) start up receiver, 4) Switch input to anything but NET/USB, 5) DON'T check for update, just use "START".
I was sure I was going to have to bring my receiver in to a service center but using the above steps, I got the firmware updates complete (2 of them!) and Pandora has been happily playing since then...
FWIW, I also found about 4pm Pacific time was a great time to hit the firmware server (it's in Japan)...
Hope it works... I totally get your frustration... Been there...
Worst case, take it in to a local service center and have them do it...
Ron
Ron
I paid 650 in June 2012 NIB
