Originally Posted by JD in NJ
I just don't see how having another remote that fails to work correctly could interfere with another remote control's functioning, unless said remote is constantly pumping out IR flashes that just happen to interfere in just the right way with the flashes the Denon remote is sending, and also does so while you're using other buttons on it.
Exactly, that is the frustrating part. My Denon receiver remote worked just fine before the addition of the Harmony 1. I went on Harmony's website to manually teach the commands I'm having issues with and that still didn't work.
***EDIT*** I just covered the Harmony with a blanket and the Denon is fully functioning. So the IR from each remote must of been interfering with the other. However, I still cant get the Harmony to do certain functions with the Denon covered up. At least I have one working and I can run Audyssey.
Thanks for the help JD.
