AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 570
post #17071 of 17914
Even though you may have just posted yesterday, it always helps to indicate the AVR model number you have (2112CI in this case) as we cover 7 different models in this thread. Thanks.
1. AMP ASSIGN allows you to "assign" the the Surr Back/Amp Assign speaker posts to several other settings as noted in your owner's manual. The factory default setting is Zone 2 and is the correct setting with a 5.1 or 5.0 setup.
2. Your ears? Have you read the Audyssey 101/FAQ linked in my sig to ensure you have setup AUdyssey properly?
3. The AVR can only play what it receives. Not all stations that indicate DD actually broadcast in DD 5.1. Note that when the display reads DTS Neo:6, that is just one of the simulation modes used when a stereo signal is received. The more common setting woud be DD PLII - Cinema if you want to change it by pressing the MOVIE button on your Denon remote. Note also that normally there isn't going to much audio going to the side surrounds unless you're playing an action movie with a lot of sound effeccts. For the Superbowl, you may prefer using the "Mult CH Stereo" surround mode which will play the FL/FR audio in the SL/SR speakers and is generally a better mode to use with parties or when lots of people are milling around and the 5.1 surround sound isn't so important.
4. Yes. Press the "CH Level" button on the remote (noted in yellow in image below) and select the speaker/sub you want to adjust and then adjust the volume accordingly.
5. If you do a lot of movie/TV watching, you'll want to add a comparable sub to your setup sooner rather than later. wink.gif
post #17072 of 17914
Wow you're a wealth of info, awesome. I did read the Audyssey...I had one question on that I'll get to in a sec.
I thought most HBO and Showtime etc shows were broadcast in Dolby? Is that incorrect? I just went through 8 HBO stations I have, and only 1 of them comes back with "dolby" on my AVR. The rest are the Neo setting. Just seems strange.
You said "Not all stations that indicate DD actually broadcast in DD 5.1." Just wondering...why? I mean if the station states thats how it's broadcast, why wouldnt it be broadcast like that?
Finally back to Audyssey...I read this:
"It is important to activate MultEQ by selecting one of the target curves. This is not performed by default after the calibration is finished and must be selected by the user. In a THX system we recommend using the Flat setting that allows the re-equalization to work as intended. In other systems, we recommend Audyssey for movie playback and Flat for music playback. Unfortunately, the music industry does not have any mixing standards like the movie industry so some music program material may sound better with the Audyssey setting. Front Align also uses the Audyssey process, but it does not apply the filters to the two front loudspeakers. Manual is not an Audyssey setting and does not use MultEQ filters. It is a simple parametric equalizer and will be subject to all the limitations that come with parametric EQ."
How do I ensure the bolded part was done by me correctly? And what the heck is a "target curve?"
Sorry for all the questions, this is all new to me. Thanks again.
post #17073 of 17914
You apparently plucked that info from another site which was written 5 years ago for another brand of AVR as on most current model AVRs (but more specifically on Denon AVRs) the Audyssey MultEQ "regular" curve (as opposed to the "Flat" curve) is automatically set after you run the AUTO SETUP process (so there is nothing to "activate") and is generally used by most owners for all types of music, although some prefer the Flat curve with Music or in smaller spaces.
As far as the DD is concerned, ensure you have your cable/sat box setup for Dolby Digital to be enabled (or ON). If you are not getting DD from any of these HD stations then more than likely the cable/sat box is not setup correctly. However, if you see Dolby Digital displayed for some stations and not others, then as I mentioned before it generally means the station broadcasting the video has chosen not to broadcast the DD 5.1 track.
post #17074 of 17914
Thanks. I will definitely check my cable box settings and report back. Do movies I record to my DVR that are being broadcast in Dolby allow for playback in Dolby? I assume so. Any instances when that wouldn't work?
I got that info from here btw: http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1
post #17075 of 17914
Yes, as long as there is DD on the audio track it will play back regardless of whether live or recorded. Yeh, I would defer to the Official guide posted in my sig as that was just info provided in a "general" context and doesn't apply to Denon AVRs.
post #17076 of 17914
Help!
I have had my 3312 for about 18 months. It is beginning to cut off during a Bluray play at elevated levels. This occurs when the cabinet door is open with plenty of ventilation. The unit is a little warm but again has plenty of ventilation. I can get through the Bluray with the volume turned down. There should really be no reason for it cutting off.
There had been no change in my speaker configuration. I have 5.2 set up with front/height.
Any input from users would be much appreciated as to why this keeps happening.
post #17077 of 17914
This usually means a loose speaker wire from one speaker post is touching another post so pull the AVR out of the stand and visually check all speaker post connections. If there is any in wall wiring, it can also mean that the wire casing has been breached by a nail or other sharp metal object.
post #17078 of 17914
I use banana plugs if that makes a difference, but I'll check for sure. Would running Audessey tell me enough about the connections? It's only when playing at louder than normal levels.
What about dust inside housing? Someone mentioned that to me tonight,
post #17079 of 17914
Audyssey? No. I'd look for a loose wire strand. Also if you are connecting to a wall plate, check there as well as at the speakers themselves.
post #17080 of 17914
Deleted and re posted in xx13 thread.
Edited by Teletodd - 2/3/13 at 8:22pm
post #17081 of 17914
I would say that cannot be ruled out. I have a computer that needs to have its CPU cleared of dust every few months or it starts shutting down.
post #17082 of 17914
Don't forget that "Dolby Digital" does not necessarily mean "5.1". Dolby encoding is used for only 2 channels, too. When only 2 channels are provided, then ProLogic and Neo:6 options are available. When 5.1 channels are provided, then ProLogic and Neo:6 can't be applied because all of the audio channels are already active. Sometimes broadcasters transmit 5.1 but only provide audio in the front two channels. This results in only the front speakers generating sound but ProLogic and Neo:6 not being available frown.gif If you actually have a speaker system with 7.1 or more speakers, then there are options in the receiver to extend audio to the additional speakers.
post #17083 of 17914
Saw this just last night with the music channels provided by FiOS. Dolby Digital signal encoding two channels.
post #17084 of 17914
What are the differences between the denon 2809ci and 3312ci
Thx
post #17085 of 17914
@Selden,
Thanks for posting this. It explains something that has puzzled me ever since I got my 2112. (why ProLogic and Neo modes are not always available, even though the AVR displays DOLBY D).
You indicated that Dolby encoding can be "used for only 2 channels" by the broadcasters. Did you mean to say 2.1? IE - is there a Dolby mode that encodes only 2 channels, and another for 2.1 (and a third for 5.1)?
post #17086 of 17914
Note that it's also possible that the TV station is broadcasting a 2CH signal over a DD 5.1 track in which case the AVR believes it's receiving a 5.1 signal (even though audio is only heard from the FL/FR speakers) and therefore no simulation mode (eg DD PLII, DTS Neo:6) can be used.
post #17087 of 17914
** Audyssey MultEQ XT Questions **
Hey guys, just picked up the Denon 1712 from A4L a few weeks ago and ran MultEQ XT. I like what it's done with everything in my setup, BUT it's made the tweeters too hot I believe. I'm getting some static or a kind of distortion from my tweeters (possibly upper midrange from the midrange drivers, but it sounds like the tweeters to me). My question is has anyone had this problem with Audyssey? I've got the EMP e55ti's toed in towards my main listening position, all 8 measurements were taken within 1-2 feet of that main position, etc. I've just discovered it shows you the (I think...1/3 octave) bands of what it did for the EQ (ie......+3db @ 40hz, +2.5db @ 60hz, etc etc....all the way through 20-20kHz). Can I just take the measurements Audyssey found (distance, levels and EQ) and manually put them in? Will that yield the same sound?
My reasoning is I'd like to put in the distance, levels and EQ of what Audyssey found into "manual EQ" and play with the top end a bit to see if I can get that resonance/distortion sound to go away.
-- I thought I should mention that it's obvious on speech parts in Black Hawk Down, Hotel Translyvania and Seal Team Six. Those are the only 2 movies I've watched since I've done it. I've listened to quite a bit of music and I don't feel like I'm getting it nearly as bad (if audible at all) in music. It sounds like resonance or distortion to me, but it's of course...hard to describe if you're not here and can't hear it for yourselves. When I take it OFF Audyssey I can keep it at the same volume level on the AVR and not hear what I'm hearing.
Edit: Just realized I'll likely loose Dynamic EQ huh? Dang. I liked having that
Edited by ousooner2 - 2/4/13 at 12:24pm
post #17088 of 17914
Thx
Both receivers have MultEQ XT for calibration, as well as Dynamic EQ + Volume, so the "raw" sound quality should be pretty similar.
As you would expect, in the intervening 3 model years there have been some feature advancements as well as some concurrent scale backs in bulk. The 2809ci weighs 28lbs 3.5oz whereas the 3312ci weighs 26lbs, so about 1kg of weight has been shaved off. Some of this is due to the a reduction in dimensions, as the 3312 is about 1.25 inches shallower and a few millimeters shorter, but in general there is a trend for receivers to get a bit lighter all around.
Another factor in weight reduction is a scale back of legacy connections, for example the 3312 has removed multich analog inputs, a lot of s-video inputs and a few composite video inputs, a component video input, and one digital input and output. In return of course you gain more HDMI connectivity (2 more inputs on the back, 1 in the front, plus dual monitor outputs) and networking.
In terms of features, some notable things which the 3312 has the 2809 does not include:
- Audyssey DSX
- Networking (including Airplay, Pandora, Internet Radio, etc. plus the ability to control the receiver from a smartphone or browser)
- HDMI 1.4 (includes 3D support and ARC)
- More advanced video processing
- Full color GUI which can overlay on all video signals
- Dynamic EQ Reference Level Offset control to allow you to tune Dynamic EQ more appropriately for each source
Some other minor differences but that's the big stuff.
post #17089 of 17914
Thanks JD
post #17090 of 17914
As this is a refurbished AVR it is possible that there is still a problem with the unit that was not detected by QC. Do you have another set of speakers that you could connect and calibrate to see if a similar problem appears?
post #17091 of 17914
- Audyssey DSX
What is the audyssey dsx
post #17092 of 17914
a system to quickly and easily calibrate your home theatre system to your room biggrin.gif
post #17093 of 17914
*bzzzzzzzz*
post #17094 of 17914
Well after looking at the EQ, I think it's added way too much on the high end and that's resulting in that distortion I'm hearing. Here's what it gave me:
Front Left
63hz: +1db
125hz:+0.5db
250hz: +2db
500hz: +1db
1kHz: -0.5db
2kHz: +3db
4kHz:+1.5db
8kHz: +2.5db
16kHz: +3.5db
Front Right
63hz:+1db
125hz: -1db
250hz: +1.5db
500hz: +1.5db
1kHz: -0.5db
2kHz: +2.5db
4kHz: +1db
8kHz: +4db
16kHz: +5.5db
Center
63hz: -1db
125hz: -2.5db
250hz: +5.5db
500hz: +5db
1kHz: +1.5db
2kHz: -1.5db
4kHz: +2.5db
8kHz: +3db
16kHz: +3db
post #17095 of 17914
hi guys, is there a maximum file size of jpg or jpeg picture files to be opened? i've connected the 3312 to a nas but its not reading all the pictures in a folder.
post #17096 of 17914
Good question. Not sure if anyone has ever posted of a max file size. confused.gif
post #17097 of 17914
Adds Front Height and Front Wide speaker capability.
http://www.audyssey.com/audio-technology/audyssey-dsx
post #17098 of 17914
This issue may be answered with the Audyssey 101/FAQ post below ....
http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1/51700_100#user_a9
post #17099 of 17914
Front Left
63hz: +1db
125hz:+0.5db
250hz: +2db
500hz: +1db
1kHz: -0.5db
2kHz: +3db
4kHz:+1.5db
8kHz: +2.5db
16kHz: +3.5db
Front Right
63hz:+1db
125hz: -1db
250hz: +1.5db
500hz: +1.5db
1kHz: -0.5db
2kHz: +2.5db
4kHz: +1db
8kHz: +4db
16kHz: +5.5db
Center
63hz: -1db
125hz: -2.5db
250hz: +5.5db
500hz: +5db
1kHz: +1.5db
2kHz: -1.5db
4kHz: +2.5db
8kHz: +3db
16kHz: +3db
The response that Audyssey is seeing in your room does not jibe with the specifications for your speakers very well. The manufacturer states "40Hz-20kHz ±3dB", and while your room has an effect, that +5.5 dB at 16 kHz is jumping out at me saying "look! I'm a problem!". That front right speaker is either a bit defective or is in a bad position, IMHO. The dip around 250 to 500 on the center is of concern as well.
post #17100 of 17914
Thanks. I'll have a look
Yeah that's what I was thinking. They've been measured by Audioholics and various other places all showing +/- 2db-ish. I have a large room (3600cubicfeet and open), but I wouldn't think it's attenuating the highs that much. No room treatments or anything.
I'll run some pink noise through them individually and see why I might be getting these results. Any other ideas besides doing this and seeing if I can hear that their down in spl too much or something?
I wonder if phasing issues up high would cause that bump? I know (or thought I did) when you get that high where the +5 and +5.5, etc are that it's mostly spl/level matching that we can pick out problems with over phasing issues, like down in the midbass/subbass area.
