AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 576
post #17251 of 17928
Originally Posted by doctorwizz View Post
Sent this unit Feb 12 by UPS to Denon's Panurgy OEM repair in NJ . They received Feb 13. They shipped today Fedex which is coming tomorrow. Sig required.
That is a great turnaround time for a repair! Would have been weeks if it was taken to a local shop before they could even look at it.
Did you buy from MacMall? I did as well, but I was under the impression it was only a 90 day warranty from them as opposed to 1 year from accessories for less, etc. My 2312 is on the fritz and I'm way past 90 days but not over 1 year. Did you call Denon or Macmall? I need to try resetting the microprocessor when I get home tonight but I don't expect any good news.
post #17252 of 17928
Originally Posted by Douglas Todd View Post
used airplay and did a hard turn-off of iTunes without disconnecting.. so far so good after the reset.. we'll see how it goes..
Did a 4 hours airplay session in both zones last night while using our firepit out back ... hard turn-off on iTunes again, and the 1912 is behaving still.. Looks like I MIGHT be in the clear (fingers crossed) thanks for the suggestions guys!
I guess the firmware/processor just gets gummed up sometimes and needs a whack?
post #17253 of 17928
Is it risky to connect L/R/C 6 ohms & surrounds 8 ohms to an Avr 1912?, 5.1 setup.
post #17254 of 17928
post #17255 of 17928
The best way to ensure the avr network doesn't gum up is hit the stop button on your avr remote and back out using the return button on the remote when ever using Airplay or any other networking feature. The problem is even though you close out of iTunes or networking, sometimes the avr still has Airplay or networking just laying there.and it will gum up and jam.
If this happens usually unplugging avr for a few minutes will resolve this problem.
post #17256 of 17928
That's incredible. Hope it's all better now!
post #17257 of 17928
Originally Posted by larkowski1 View Post
So this afternoon, I was listening to music at very moderate volume (-30) on my 2312 and the 2 front (L and R) speakers cut out accompanied by a relay click. After a few minutes, they come back on again with a click. The display says nothing out of the ordinary, no messages, blinking lights, etc. So far, I've checked the speaker wires (swapped them with the ones from my bedroom setup) and if anything the problem is worse. This evening, it did it again several times on lower volume while watching TV (different input and connection - hdmi from the music this afternoon - optical toslink cable). In 5.1 mode, the center and rears are fine. I've also tried unplugging the unit for a few minutes with no change.
I can swap my speakers (PSB T45s) with my bookshelves from the bedroom (Monitor Audio RS1). I can also do a microprocessor reset. Is there anything else I should be trying or is it time to go receiver shopping again pending those other two things I just mentioned? I bought it refurbished over a year ago, so my warranty is out....
Well I reset the microprocessor and no joy. No sound out of the mains when running Audyssey. Also, I tried other speakers with the same result. Tomorrow morning, I'll call Denon I guess.
post #17258 of 17928
Anyone else experiencing issues with the iOS Denon Remote app since the 2/13/13 app update? It worked flawlessly for me for a year on my 2112. Since the update, when I open the app it appears to be focused exclusively on identifying and controlling my media server(s). Options for power, volume and zone and source select are not even listed now. Oddly, it still works on my 3311. The 2112 shows the firmware as being current, with no update option.
Thanks for any help.
post #17259 of 17928
Working fine on my iPhone. Delete and redownload.
post #17260 of 17928
edit: just realized i posted in the wrong thread - sorry - ignore this
Edited by gothaggis - 2/19/13 at 11:32am
post #17261 of 17928
I take that back; showing volume at -22.5dB, instead of 58.5 (how I have it set). Oops, now has 58.5, I turned the iPhone OFF for about 30 seconds.
post #17262 of 17928
Originally Posted by batpig View Post
It's dictated by the source. DTS vs. Dolby is an audio encode that will be part of the source itself. When the receiver receives a Dolby Digital signal, it will decode Dolby Digital. Same for a DTS Surround signal.
Note that this applies to MULTICHANNEL inputs. When you want to "upmix" a 2ch stereo input to 5.1/7.1 surround sound, then you apply whichever "post processing" scheme you desire. In this case, you can choose between the Dolby and DTS flavors (Pro Logic vs. Neo) or Denon's built-in modes like MultiCH Stereo.
It's confusing but the key is to understand the difference between discrete multichannel inputs, where it's already coming in as 5.1 audio packed into a codec like Dolby Digital, and all the receiver has to do is unpack the audio from the encoding container, versus stereo inputs where the receiver has to apply additional processing to mix the extra channels.
Does it default to "standard" after it has selected the surrounds source based in the input (e.g. Dolby Digital, etc.)?
post #17263 of 17928
The repair ticket dated 2/15/2012 said "REPAIRED POWER SUPPLY. Unit has been cleaned, checked and all functions have been tested."
Part number: 963682010370S
Part Description: AVR791 RL 101
My 3312 had the rebooting problem like in this video:
http://www.youtube.com/watch?v=mlfnouCgsRw
post #17264 of 17928
Any 5.1 sources--- will play what it receives. No choices
2 ch source ---Your choice Dolby PL or Dts Neo 6 or Multi Ch Stereo etc...
Note; 2ch sources, if you turn Auto Surround Mode to ON it will remember and call the last stored mode automatically per input. So if you like that mode you chose for a particular input, Set it and forget it. It will not change until you change it and when you change it will become the new set it and forget it. Remember each input can have it's own Set it and Forget it mode
. If Auto Surround Mode is set to off the mode you select will be on All inputs.
Edited by spager - 2/19/13 at 5:25pm
post #17265 of 17928
Note; 2ch sources, if you turn Auto Surround Mode to ON it will remember and call the last stored mode automatically per input. So if you like that mode you chose for a particular input, Set it and forget it. It will not change until you change it and when you change it will become the new set it and forget it. Remember each input can have it's own Set it and Forget it mode. If Auto Surround Mode is set to off the ounce you select a mode it will be on All inputs.
yes, thanks, that makes sense. however, when i go into the "Surround mode" menu it displays "standard". It doesnt show the source it recieved from the blu ray, etc.
post #17266 of 17928
Do you have your BD set to Bitstream? If set to Pcm it will not give you the mode as the BD player will decode the information, No difference in sound quality between Bitstream an pcm so set it to Bitstream and you should see the info on your avr.
post #17267 of 17928
I just looked and it is set to bitstream. I am using a Sony 590 blu ray player. Could their be another setting i am missing that would cause it to just show "Standard" as my surround mode on the AVR? (3312)
post #17268 of 17928
What does it say on your avr front display? It should give you the mode on the bottom line.
post #17269 of 17928
Hi MNaudioguy, on Sony 590, set HDMI Audio to "Auto" and change BD Audio Mix setting to "Off".
post #17270 of 17928
Thank you, i will make sure i do that if i havent already. I tried to change most of the defaults according to post #1 in the 590 forum
It does say Dolby Digital on the AVR display, so I am assuming things are correct. It says standard when I use the menu via the TV, however, I am assuming it is still dolby digital. I guess the only reason i am concerned a little is I feel a lack of bass coming from the front l/r that are set to Large. They are Def Tech 8060 towers with built in subs. I dont have another sub at the moment. I do have a mirage omni s-8 upstairs and I feel that hits harder than the towers, but maybe I had higher expectations smile.gif
Thank you all!
post #17271 of 17928
Hello MNaudioguy-make sure that your "bitstream downmix" is set of "off" on your Sony 590-see if that changes the "standard" message when you are sending encoded Dolby 5.1 , via bitstream, from the 590.
post #17272 of 17928
Thank you all!
There are tweaks like the Audyssey curve and restorer and others that may help with bass but I am not sure of those settings.
post #17273 of 17928
I turned Bitstream Audio Mix settings to off. I didnt see the Bistream Downmix option though.
post #17274 of 17928
I need to replace my dead AVR-789 and was looking into the 1712. Does anybody know the best place to pick one of these up still?
post #17275 of 17928
Thank you all!
Did you try turning up the sub volumes on your speakers? You will need to rerun Audyssey however.
post #17276 of 17928
no, not yet, i will probably try that though. I had them both dialed in at 12 o'clock and thought that would be good enough since some folks say they even have to turn them down. I know the room is large and that could have something to do with it, however, even directly in front of the speaker it still doesnt have that bass i was expecting. Thanks all for your help, I dont want to hijack the thread and can try a few things and come back if i still have questions
post #17277 of 17928
CNN this morning announced that Best Buy changed it policy and will Match any major online distributors prices. So if you see a good deal print it and they will match although on big ticket items you usually need to phone the online seller to get their best price.
post #17278 of 17928
Yes, I purchased 3 from MacMall.
One year warranty on Denon refurbs from MacMall. They are an authorized Denon dealer.
post #17279 of 17928
Hello
I am trying to hook a regular Wii up to get Prologic II and a picture at the same time...any tips?
post #17280 of 17928
Originally Posted by ReSultZ View Post
Hello
Oh and I have a 3312Ci and am using Component video wires for the Wii.
