AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 580
post #17371 of 17929
Finally got my front sound stage working nicely just working on the 2 surrounds just trying get them to play together nicer.Wow these denons pack a punch i notice right when i got one it opened my speakers up more there alot different the HK i gained more bass and clarity might just stick with denons avr.
Edited by ryu4000 - 3/4/13 at 5:55am
post #17372 of 17929
I am a newbie to home theater setup. But just bought the AVR 3312 and ran the auto setup. The volume isn't as loud as I expected. It's connected to 5 MartinLogan Helos 100 in-ceiling speakers. Not sure if the issue is because I don't have a subwoofer. I checked the volume limit and it is set to off.
post #17373 of 17929
Be aware that those are 4 ohm speakers and most AVR's are typically rated for 6 ohm or higher.
post #17374 of 17929
has anyone here successfully used ARC from a Panasonic GT50? I was messing with the various settings on the receiver and tv to get it to work for the viera apps, but was not successful.
I have cec on for both units, the tv source switches over when it detects ARC, but no sound from my HT speakers...only from the tv
post #17375 of 17929
Can you be more specific? Modern digital receivers have different volume structures than older units, what volume numbers specifically are you trying?
Also make sure Dyn Vol is off if you are trying to crank it.
post #17376 of 17929
Looking forward to testing it with Dyn Vol turned off. Cant remember exactly what the volume number was. I think it was in the -20db to -15db range. It gets a little loud but not extremely loud. The channel level setting for the speakers range in the -4, -4.5 and -5. Not sure if I need to bump it up.
post #17377 of 17929
The volume control is logarithmic. After calibration and with Dyn Vol off, most people listen to movies at around -20 to -25 and CDs at about -30 to -35. There's no need to play with the individual channel level settings. Just increase the master volume level.
post #17378 of 17929
-15 to -20 is typical listening levels. It does sound as though Dyn Vol is probably on, which would dampen the perceived volume. IIRC auto setup asks to enable it and defaults to on. Also bear in mind that those are smallish speakers you're using there, relatively small when compared to multi-driver towers.
post #17379 of 17929
I had alot of issue setting up my 3213, but eventually got it working. Here are a few things that I did which worked in the end. Not sure which one worked in the end... took ages to work it out.
1. change PPPoE to PPPoA on the modem / wireless router. Denon seems to prefer the PPPoA settings.
2. Turn on multicasting
3. Turn off IGMP snooping.
post #17380 of 17929
As Selden and RobLee already advised you, this is normal. You just need to get used to the way modern digital receives work with their logarithmic volume scale. The Master Volume of 0 is "reference" level with movies, which means you are down 15 to 20 dB from reference level (what you would hear in a movie theater in theory). That is a normal "pretty loud" volume level for watching movies at home. Some people like to crank it a bit higher, and by the time you get to -10 or higher it should be pretty freaking loud.
Also as noted above, Dyn Vol will blunt the dynamics meaning the peaks (explosions, gunshots, etc) will sound muted, so that may be why it got "loud but not extremely loud". With Dyn Vol off, anything between -10 to -20 would be perfectly normal "movie night" type loud volume.
Note that for other (non film) sources this kind of goes out the window. Music is often recorded hotter than films, so you may find yourself listening to CD's or streaming audio at a much lower MV setting. TV programming is highly variable as well.
post #17381 of 17929
Thank you. Thank you. Thank you. My setup sounds 10 times better now. By setting the Dyn Vol off, I was able to hear the explosions and gunshots as it was intended. In addition, thank you for explaining Denon logarithmic scale. I didnt know that you have to turn it up 2/3 of the max for avg volume level. I saw this on the first page of the thread. (e. Master Volume Adjustment: Unlike perhaps your older receiver that was really loud at say 1/4 of the max volume scale, Denon AVRs use a logarithmic scale and will require the volume turned to roughly 2/3 of the maximum for average volume levels)
post #17382 of 17929
IIRC one of the setup options is the choice between "relative" or "absolute" volume display on the front panel. Where the default setting is relative to the reference level as measured by the setup microphone, the absolute level is more what you may be accustomed to, measured on a scale from 0-100, presumably 100 being 100% maximum output (I've never used absolute myself so this is an assumption on my part).
In practice, most movies play around -20, though some soundtracks may need -10 or higher for quieter dialogue to be understood. Also as mentioned above, some music sources are played at around -40db. Although you can adjust the level of gain for each input, I've found that the +/- 6db range doesn't really allow true leveling of all sources. Note that once you find a good starting point for each input, save it as one of the quick select buttons. That way, when switching from a "quiet" source to a "hot" source you don't risk blowing a speaker or eardrum.
post #17383 of 17929
Well, I shipped my 2312 off to New Jersey today. I hope it gets turned around pretty quickly....
post #17384 of 17929
Please let us know the details.
post #17385 of 17929
I am a newbie when it comes to audio.
My setup Denon AVR-3313CI Fronts P363, Center PC351, and rears P163.
Today replaced my Polk PSW10 with a PSW 505 the price was in my budget, from all the reviews i read thought it would shake the walls I must be doing something wrong?
post #17386 of 17929
Did you rerun Audyssey with the introduction of the new subwoofer (which should be done anytime new speakers/sub are either changed out or added to the setup)? Also note that any sub you use will be calibrated to put out the same level of audio ... rather if you want more "oomph" you'll likely want to simply increase the "Subwoofer" volume level with the remote control.
post #17387 of 17929
this is a really good tip; changed positions of my surround back speakers; boys are old enough to leave them alone, so reran Audyssey... cool.gif
post #17388 of 17929
Hi all. Can someone help me trouble shoot?
I am watching the dark knight rises and its almost unwatchable from an audio point of view.
The soundtrack is SO loud relative to the dialogue that I can barely make out the dialogue. In most scenes the background music is booming and I am straining to hear what anyone is saying.
Its playing on "DTS-HD MA". I have things set by Audyssey and have not experienced this before.
If I try to select Channel Level and increase the center nothing happens - the channel level button does not respond.
Ideas?
post #17389 of 17929
All I can suggest is (1) try turning on Dynamic Volume to restrain some of the dynamic range and/or (2) adjust the reference level offset which will tone down Dynamic EQ's boosting of bass/surrounds. If it's never happened on other Blu-rays then you can be pretty sure it's just the over aggressive mix on this one. I'm not surprised to hear that this soundtrack is overcooked, a lot of people complained of similar antics with the previous movie in the trilogy.
post #17390 of 17929
I purchased open box 3312CI (like new condition with all the accessories) at BB a week ago for very good price. BB sales person said they changed the return policy and I have to return within 15 days if I don’t want it. Problem is I don’t have time to hook it up and test it. I’m splitting my hair whether I just return it and spend $170 more for pioneer 1222 ($530@newegg). Many of the review including Hometheater.com indicate that 1222 (or Elite 61) might have better audio performance. I’m not even sure if 3312CI would be an upgrade from my 5-year-old pioneer 1018, which has pretty good sound in my opinion. It’s quite surprising to hear that $1100 3312CI has almost identical audio quality as $650 2112CI except for some more wattages and features. Pioneer 1018 was around $600 MRSP so I can assume that it's same level as 2112CI. My only concern is audio quality. I don’t really care about network, smartphone functions, 3D, 4K, zone 2 etc.
Currently I have following setup in medium size family room open to kitchen. I listen somewhere between -25db and -15db. Movie/Music 50/50.
Pioneer 1018
Energy RC70s, RCLCR, RC-10s, Outlaw LFM EX: 5.1 system and want to add front wide(or height) and second sub in the future.
Source components: Dune D1, HTPC and panny bluray
I have one week to decide. Any advice would be appreciated.
Edited by m9610172 - 3/8/13 at 8:28am
post #17391 of 17929
Which provides better audio is highly debatable.
The version of Audyssey included in the 3312 equalizes the subwoofer. Pioneer's MCACC does not. As a result, the Denon will produce more accurate low frequency sound than a Pioneer receiver can. Also, unlike MCACC, Audyssey uses multiple microphone positions so it can optimize the audio for more than just the primary listening position.
post #17392 of 17929
Thanks. I did have dynamic eq on evening. Will try the offset.
Question: why was I unable to adjust channels? Is it because it's disabled for dts? Or just disabled during playback?
Would I have been able to manually switch from the dts-hd to another surround audio mode? Might that help?
post #17393 of 17929
I don't know why you were unable to change channel levels. I've never seen that before. I would try some other Blu-rays to test.
You can't really change the surround mode -- if the input signal is DTS-HD, that's what the receiver will decode and play. You can't, for example, play a DTS signal as Dolby Digital. It is what it is. The only way would be if the SOURCE itself has an option for a different audio track.
post #17394 of 17929
Thank you for your reply.
I had no idea about Denon 3312CI when I purchased it last week. It was kind of impulse buy because the price is so good. I just thought that $1100 receiver should be better in every way than the one with half price. Upon researching for a week, I saw in batpig’s review about 2112CI, 2312CI and 3312CI, “Sound quality should be the same, the "on paper" power difference is negligible in real-world use”. I started thinking that it might not be an upgrade 
As for the multi point measuring, even Pioneer 1018 provide up to 3 positions. You just have to go deep into the menu.
I was a firm believer that receiver doesn’t make big difference. I tried $200 pioneer, $400 HK and Pioneer 1018 in the past 8 years. Each time, I could hear noticeable improvement in sound quality. I am hoping that I could experience the same improvement this time but I don’t have time to test it myself before return period expires.
post #17395 of 17929
A nit-pick, but the founders of Audyssey would argue that the benefit of multiple measurements also optimizes things for the primary listening position. It's not just about optimizing for multiple seats, it's because the distribution of acoustical issues varies spatially, even over very short distances. For example, Chris always used to joke that unless your head was the size of a pin and fixed in a vice, your ears are several inches apart and your head is going to move around. So even for a single listener always seated in one seat, sampling multiple points within that narrow "sweet spot" would still yield a benefit.
post #17396 of 17929
As Selden noted above, the primary sound quality improvement is going to come from Audyssey. Since both the 2112 and 3312 have the same Audyssey MultEQ XT software, they should sound approximately equal. Their internal components (decoding chips, DAC's, etc) are the same. The only difference is that the more expensive 3312 has more features and more power. Since you mention potentially adding wides or heights, the 3312 also has the advantage of having Audyssey DSX (the lower models only have PLIIz for heights, but no option for wides).
Your Energy RC setup is fairly efficient, but if you do like to crank it really loud and/or you have a larger room, then you may find the 3312's extra power makes a difference.
I would really, really try to hook it up and test it out. Your own ears will be the best judge of whether you like it.
Since it's open box and BB is an authorized dealer, you would still be covered by the 3-year warranty if something fails later on, so that's less of a concern (although obviously more of a hassle than simply returning it to BB).
But if you don't really have time to test it, and it sounds like you paid less than $400 (which is really a steal for a receiver of this caliber) then worst case scenario you can sell it used for what you paid without much problem.
post #17397 of 17929
Hi, batpig.
First of all, I really appreciate all your reviews and overviews on denon receiver and Audyssey. It was fun to read.
I understand that different brand within the similar price range can have their own characters and not necessarily one is better than the other.
But if I upgrade from $100 receiver to $600, I’m pretty sure I would hear much better sound. I had the same idea until I read your overviews on xx12 models.
$400, $360 actually, is still a lot of money for used receiver, I’m not so sure if I can sell it on craigslist if I don’t want it.
Anyway, I am leaning toward to giving it a chance after reading your and Selden’s replies.
Thank you.
Edited by m9610172 - 3/8/13 at 9:44am
post #17398 of 17929
I'm pretty confident you can sell a used 3312ci for $400. It's a $1000+ msrp receiver and it's almost a current model, with modern features like 3D support and tons of HDMI inputs, Audyssey XT and DSX, etc.
post #17399 of 17929
I'm having an issue with my AVR-1912.
It's actually been doing it since I bought it. If I turn on say Sat/Cab to watch DirecTV, it would not play any sound unless I hit another input (such as BD) then re hit Sat/Cab, and only then i'd have sound.
After a firmware update not too long ago, it does the same thing, but now won't display the TV at all, just blue screen, until I do the input select switch.
Just annoying to have to switch back and forth every time to do anything on initial start. There anyway to fix this?
post #17400 of 17929
One for JD and BP and anyone else interested:
2112ci
Just a FYI that I was experiencing what I believe(d) to be a faulty HDMI board - Randomly the unit would flick to HDMI 2.
A processor reset seemed to cure it for about 6 months then it came back again.
Another processor reset (10 times at once to be sure) and it was still doing it. At least three times a session of a few hours.
Just for the heck of it I set the system into HDMI Control ON (Standby Source - Last / Power Off Control - Off)
I have not had the issue for a good three weeks.
Not sure why/what/how, but there you go.
Edited by pieandchips - 3/8/13 at 11:34am
