Originally Posted by jdsmoothie
"At that point, if the TV is powered on or off, it will reactivate the CEC communication and the 2112 will then switch to it's default "TV" source. The work around for this, as you found out, is to disable the CEC function of the TV."
As indicated in the above quote, the Denon rep also noted that if the TV is cycled ON/OFF it would reset the default to TV and result in the issue that kyxapka is talking about ... which is, by setting HDMI-CEC to ON it sets the AVR's startup source to TV and then restricts output from any other source to include the Standby HDMI source (eg. cable/sat box). Although the Denon rep who responded was likely Ean, who is reliable, I'm still waiting on the final word from Denon as to whether this issue is resolvable or not.
If there are any XX11/X91 owner's reading this with HDMI 1.4 TVs w/ARC it would be interesting to see if the same issue results with those models as I don't recall this issue being raised in any of those threads.
JD isn't the signal coming from the TV so I would expect this exact behavior? In other words the TV being cycled is sending some form of request to the AVR saying hey imready to do something..
I'd give them a call. Please post back though of your results and the proper steps to take if possible. Thanks.
