AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 99
post #2941 of 17928
Originally Posted by Graymd74 View Post
I recently purchased a 2112CI and have it connected to a JVC HD-DLA, DirecTV and a PS3. Upon set up I had no issues and was even getting 7.1 sound out of the PS3 which I was excited about. After about a week I started having what I thought were HDMI handshake issues, but only with the PS3. I followed advice in this thread on how to reset the HDMI on the PS3 and the order in which to turn on the components to minimize this issue.
Things worked well for another week until the power went out overnight for about a minute. When I attempted to use my PS3 it wouldn't recognize the HDMI and I just had a black screen. I tried to hook the PS3 directly to the TV and reset the signal and still had no luck. I tried the PS3 on another tv with HDMI and it worked just fine. I'm thinking the issue is with the tv, but the DirecTV works fine in all 6 inputs on the 2112CI and the PS3 is not recognized in any.
I gave up today after trying 5 or 6 different HDMI cables I had at the house and picked up a component cable for the PS3. Hooked directly to the TV it works just fine, unlike the HDMI, however, hooked to the 2112CI via component I only get a full green screen. Last but not least, when I use the component cables with my TV and the HDMI from the PS3 to the 2112CI, it runs the sounds in 7.1 with no issues.
Why can I not use my HDMI through the 2112 for my PS3 anymore when other HDMI works just fine? Why do I get a green screen when I try to connect my PS3 with component cables through the 2112, but perfect picture through the tv? Why does the sound work from the PS3 to the 2112CI but not video? I have tried everything I know and will use the set up of component through the tv and audio through the 2112, but I really wanted it all running through one system to minimize remotes, etc.
Can anyone shed any light on why this connection is failing?
Have you tried hooking up the ps3 to the tv with both the component and hdmi, then changing the video output settings? ie start with the output over component, then select and adjust HDMI. My ps3 used to drop sync all the time, (i have an original 60gig), and i would have to reset the output all the time. Its a pain in the butt, but having an alternate output while you adjust the hdmi settings is the only way to fix the issue.
post #2942 of 17928
Originally Posted by PerfectCr View Post
This is really driving me nuts. I don't get it. No matter what I do, the "XT" portion of the MULTEQ XT front panel indicator light will not illuminate.
Sorry to keep quoting myself, but in post 3 it says...
....As long as it's < -12db you're good to go to complete the remaining 5 (MultEQ) or 7 (MultEQ XT) positions.
Does this mean MultEQ XT is only available in 7.1 setups? Mine is 5.1. Does this explain why the XT is not illuminated?
post #2943 of 17928
I actually did this successfully the first couple of times and set the HDMI settings to match the tv and took it off auto. I agree with you its a pain in the butt. Now that no longer works and gives me an all black screen that flashes for a second and then goes all black again. I'm starting to see more issues with full green screens which is making me focus on the tv inputs being the problem and not the AVR. Might be time to upgrade the tv.
Do you happen to know if an HDMI signal is stronger or different from a PS3 signal? Just wonder why I'm having problems with the one and not the other. Plus the all green screen when selecting internet radio is concerning as I'm not sure how that navigation screen is displayed and why its not showing correctly.
post #2944 of 17928
No, that is in reference to the number of mic readings you can take when you run your Audyssey setup -- 8 for MultiEQ XT vs. 6 for MultiEQ. [Specifically, it's advice for setting up the subwoofer -- to take just one Audyssey reading until you get the sub dialed in and not maxed out at -12dB. Once you get a good sub reading, then you run the full set of 6 or 8 Audyssey readings.]
post #2945 of 17928
Audio quality wise (as the 1912 doesn't have a video chip whereas the 791 does) .. they're both the same as they both use Audyssey MultEQ. But feature wise, the 1912 stands out as it not only uses a GUI that can overlay 2D video but also uses networking and Airplay which will allow you to control the AVR with a smart phone from anywhere in the house that has access to your home network. Although if money is not the issue, spring for the next model up, 2112CI which offers a better version of Audyssey MultEQ XT as well as a 3rd year of warranty.
The ABT video chip only applies to upconverting analog signals, right? It wouldn't affect any 1080p input or 720p input from an HDMI source, correct?
post #2946 of 17928
Originally Posted by TalkingRat View Post
No, that is in reference to the number of mic readings you can take when you run your Audyssey setup -- 8 for MultiEQ XT vs. 6 for MultiEQ. [Specifically, it's advice for setting up the subwoofer -- to take just one reading until you get the sub dialed in and not maxed out at -12dB. Once you get a good sub reading, then you run the full set of 6 or 8 Audyssey readings.]
Ok thx for the clarification. So I am still at a loss then as to why the XT is not illuminated. All references to the indicator light on the Denon website and the owner's manual for the 172 show the XT illuminated. There must be a specific reason why it's not on.
post #2947 of 17928
Originally Posted by bush224 View Post
Hello,
I am setting up my Denon 1912 with a 5.1 system from B&W. I have done the audyssey mic and I get sounds out of all the speakers including the sub.
Now here is my problem, I have tried the Dave Matthews bluray (radiocity) and it should be playing in trueHD however for some reason the receiver isn't cooperating. I noticed it that the sub is not playing at all. I also have this issue with other high def programing. During the test the sub works fine.
It is connected with HDMI. Under the info section in the menu it says the audio is in 2/0/.0 I cycle through the different options when I hit MUSIC and MOVIE buttons on the remote but the only options I get are Dolby IIPx, NEO 6, and things like virtual. I have tried putting it into source direct (I think I did that correctly) but nada. I CAN get sound from all the speakers with the dolby and neo settings but I am looking for trueHD but according to the manual the settings I get are given to me because the receiver is only seeing 2.0 setup? Is that right?
Anyone have an idea what setting (maybe even an AUTO) I am missing on the receiver that is not allowing 5.1 to come through? I remember on an old integra 9.8 it automatically detected if trueHD was playing and put it in that mode.
This is telling you that the BDP is only sending a stereo 2.0 signal. Select the proper audio track on the BD and set the BDP to "bitstream" and secondary audio to OFF (if that setting exists) and you should be good to go.
Ok, I changed the PS3 setting from PCM to bitstream but still I am not getting TrueHD to show up on the receiver NOR am I getting 5.1. The info still says 2.0. I do not see any setting on the disc itself.
I also can not get 5.1 to fire when watching HD movies on HBO/Cinemax via directtv.
I have to be missing something but for the life of me, I can't find anything pertinent in the receiver menus.
Any ideas?
post #2948 of 17928
Originally Posted by tandy1000rl View Post
Let me know how this works out for you. I'm going to try the same thing with a Sunfire receiver, in my case to provide better 4 ohm support than my 3312 can provide.
Another thought to consider: because 5.1/7.1 analog inputs are generally designed to take a fixed line level input from a blu ray player (vs. the variable line level the denon preouts will provide), first setting the Denon to a fixed volume (ideally, just shy of clipping the preouts), then only using the volume control on the external receiver acting as the amp may work better overall from a signal-to-noise ratio perspective. Of course this method works if all speakers are connected to the secondary receiver only.
I agree though, it's difficult to part with a older receiver that has an awesome amp section just because it's preamp section is out of date, so any creative method of repurposing it is definitely worth the experimentation.
Well I finally got it worked out. I think it had something to do with accidentaly selecting a second zone setting or something when playing around with the amp assignment settings.
For those people who have questioned the wisdom of using an old Sony amp rated similar to the Denon 3312, there is significant difference with the fronts now running through the sony vs denon.
Before when I had all running via the 3312, the max comfort level before I worried about something rattling loose in the house or waking up the neighbors was 0db. Now running through the sony set on 3/4 volume, the max comfort level is -10db on the Denon volume level.
I first got things working right while running fronts through an old NAD 150 watt/chan. amp. that is supposed to be a beast, but when I switched out for the Sony, the sony on 3/4 was still louder than the NAD on max.
Anyway glad to now have all the new bells and whistles of the new Denon but still enjoy that brut strength of that old 60lb Sony.
post #2949 of 17928
you are looking in the wrong place, it has nothing to do with the receiver. All it can do is play what you give it, and this:
... means your sources are not configured correctly.
If the receiver reports 2.0 input, that's what it is getting. It can't control what the sources send, that's your job keep at it! it's a setting on your sources that's off.
post #2950 of 17928
I think I am stuck in never never land. I used the load function tp load my seting back after a firmware update on a 2112ci. I am looking at the red button and the loading screen is 20 minutes on. Looks like time to pull the plug. God only knows what will happen then, '
the firmare downloaded fine. widh me luck!
post #2951 of 17928
Originally Posted by jconjason View Post
Positive. I had to move my sub last night so reran Audyssey, saved the file and called 'er a night. Woke up to the FW update right away. I will contact Denon. Thanks!
I would check your SAVEd file then to confirm the AVR is actually saving anything as in some cases a few of last year's owners indicated it was filled with zereos.
post #2952 of 17928
Originally Posted by bdr1 View Post
Also, I now noticed that when I turn off the 3312, the green light around the on/off button just goes out. It does not change to red like it used to.
The "red light" only appears if you have HDMI Control or Network Standby set to ON (post #3, item 2h).
post #2953 of 17928
Correct, although 720p would still be deinterlaced/upscaled to 1080p, that particular chip really only works on SD signals, although it may do no better than your BDP or TV itself.
post #2954 of 17928
Could just be the light is out .... as XT is installed, it would be enabled once you completed AUTO SETUP.
post #2955 of 17928
Please report back with your experience as it is important to note whether this completes successfully or not.
post #2956 of 17928
Ever since the firmware update Airplay isn't working.
When I open iTunes I no longer "see" my 3312 in the AirPlay icon at the bottom right corner of iTunes.
Have others experienced this issue or do you have any suggestions?
Network standby is set to on and I have't changed any settings since AirPlay was working.
George
post #2957 of 17928
Try resetting your router and at the same time unplugging the AVR for a few minutes.
post #2958 of 17928
JDSmoothie
THANKS!
That did it.
George
post #2959 of 17928
Could it be that I didn't run the test 8 times, only once during Auto-Setup? I'll try that today otherwise I am going to return it and get another.
post #2960 of 17928
Not likely as only one position is required to save the settings although you should always run AUTO SETUP the max number of positions 6 (MultEQ) or 8 (MultEQ XT) unless just testing the sub in different locations or volume levels in which case you need only run a single position each time until you're satisfied with the sub trim and then run all remaining positions.
post #2961 of 17928
Not likely .... although regardless you should always run AUTO SETUP the max number of positions unless just testing the sub in different locations or volume levels.
Do you have the 1712? I know it just came out but I'd be interested to know if other 1712 owners are seeing the XT illuminate. Thanks!
post #2962 of 17928
No I do not .. however, perhaps other 1712 owners can chime in. Either that or you can use the Search This Thread button and identify other 1712 owners and send them a PM.
post #2963 of 17928
My wife's parents are staying with us to help take care of our 5-month old while we get ready to move to a new house. (They are terrific people, not the stereotypical in-laws at all.)
Last night, my mother-in-law comes in the living room and asks if she can turn down the TV and I say "sure!" She picks up the Denon remote, takes a moment to find the volume buttons, then tries to turn it down. It does nothing for a moment then slams the volume all the way down. She apologizes and tries to turn it back up, and ends up turning it up louder than it originally was because she left her finger on the button a fraction of a second too long. She does this undershoot/overshoot thing a couple more times before giving up on trying to hold the button down, and tapping (in 0.5dB increments) until she gets it to a point she's happy with.
This really could be the one thing that forces me to jump the Denon ship.
post #2964 of 17928
You have a number of different options available to you ...
(a) Set the Denon to come on at specific level (ie. normal TV viewing volume) so no volume adjustment is required,
(b) Set the Volume Limit to -20db.
(c) During the in-laws visit, connect the cable/sat box directly to the TV with optical to the AVR so they don't have to turn the AVR on at all.
post #2965 of 17928
Well, I just did the auto-setup again (8 times!) and the XT still won't come on. I did a Micro Processor reset, and all of the lights WORKS (they all blinked while resetting). Upon redoing the auto setup, the XT will still not illuminate! I did get an out of phase error on the Surround Left speaker. Could this cause it? I am beginning to wonder if the MultEQ XT is enabled. The light works, but something is stopping the receiver from enabling the indicator light.
post #2966 of 17928
You cannot directly relate one mfr's volume scale to another as they may be different (eg. older receivers that will max out at maybe 1/4 of the way). Denon uses a logarithmic scale which requires the volume dial being turned almost 2/3 of the way for average level volume. Also, Denon AVRs generally rate much closer to their marketing specs (80%, 3311CI bench tests @100W into 5CH) then do other brands like Sony (~50%). Of course you gain headroom in the 3312 using the Sony receiver, however, in reality the surrounds require very little power. Certainly no reason not to use old equipment if it's available, but not really required with 8Ω moderately efficient speakers.
A Zone 2 setting on the AVR should not have had any impact on the preout jacks. If you can recreate the issue please report back as there may be a bug in the system. Thanks.
post #2967 of 17928
Well I fixed the out of phase error, still not XT illuminated. The light works I know that. Might have a faulty unit. Will exchange today. If the next 1712 does it, then it could be a firmware issue.
post #2968 of 17928
Great to hear. So did you do just left, right, and center thru the Sony or all channels? Also, when you turn the Denon volume down low, leaving the Sony receiver fixed at 3/4 position, do you hear any low level hiss or other noise coming from your speakers?
When doing MultiEQ setup, did your front 3 speakers get trimmed way back relative to the others? Finally, is the overall system volume objectively louder at the point where the speakers begin to clip/sound harsh compared to the Denon only setup? Exactly where this happens on the physical volume control isn't as important to me but more interested that you achieved an additional 1-2 db overall system volume before clipping, or that it "sounds better/less distorted" at louder volumes vs the denon only setup due to the additional headroom.
Most folks may not hear a 1-2 db increase in system volume but some probably can hear a reduction in distortion at higher volumes that the additional headroom provides, which is really the driving force for the external amplification crowd. We don't want more volume, we want a cleaner high volume. :-)
post #2969 of 17928
Well .. just to confirm the front height setup is not somehow causing the issue, disconnect them from the AVR speaker posts and reset AMP ASSIGN back to Zone 2 and do the AUTO SETUP again for 1 position only to see if you get better sub trim results.
I was changing the "Volume Speaker" knob, not the "Volume Line" knob. Apparently, the "volume speaker" knob does not change anything when you have the sub hooked up through the line sub cable.
post #2970 of 17928
Any ideas?
Not sure about 5.1 in but you can always output 5.1 using Multi Ch Stereo just hit the simulation button on your remote till it comes up MCS. I sometimes use this when 5.1 input and usually during 2.0 input except for music but even then I find it quite pleasing.
