AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 105
post #3121 of 18066
Just like SATA connectors in PCs. Hopefully manufacturer's will start incorporating security clips like many SATA cable manufacturer's now do.
On the subject, I just bought a 2112CI, it's still sitting in the box in my truck. My cable company provides an STB that has component and DVI outputs only. Audio is stereo via RCA or optical. I am trying to clean up the cabling as much as possible behind my set up, is there any downside of using the DVI output with an HDMI converter rather than the component connector on the STB?
post #3122 of 18066
downsides:
1) potential for HDMI handshake problems (see: HDMI sucking balls, above)
2) inability to mix music from another source with cable TV video via Video Select (in case you want to listen to music while watching the game or something)
I would go with component + optical, personally. It's not going to be that much more cabling (you have to use separate audio anyway) and will be rock solid.
post #3123 of 18066
On Windows 7 sharing issues, make sure you have password protected sharing turned OFF under "Advanced Sharing". On the same dialogue, change the encryption settings to allow sharing with devices that only support 40 of 56 bit encryption. These changes will allow easier connectivity to devices that don't conform to Windows 7's rather rigorous security requirements.
I will have my 2112CI at home today and will be doing lots of screwing around with streaming to/from various PCs, so I may have more usefull info later.
post #3124 of 18066
Ball suckage noted for future reference!
Will do as you suggest. Thanks!
Originally Posted by batpig View Post
downsides:
post #3125 of 18066
Quick question
I am watching a streaming movie via vudu. The voice is slightly off and I have auto lip-sync on. I am playing this through my blue ray player
One other thing..... I Checked the delay. And I see there is a setting from 0 to 200. What I actually need is a negative delay. I have auto lip sync on
So how do I fix the voice sync issue
post #3126 of 18066
Deleted
post #3127 of 18066
Originally Posted by benalexe View Post
Quick question
Seems to be a blue ray settings issue.
Which output do I set it at?
PCM stereo
Bitstream hd
Bitstream legacy
PCM 5.1
Should PCM down sampling be on or off? If on I can set it or 96 hz 48 hz or off
What about dynamic range control? On off or auto?
Stereo down mix. On off or auto?
post #3128 of 18066
downsides:
...unless said STB outputs 1080p, which you can't get over Component. So if it outputs 1080p and you really WANT 1080p, you'll want the DVI connection in spite of the potential complications.
post #3129 of 18066
The TV speakers should be muted when using the AVR unless the HDMI Audio Out setting (p. 89) is set to "TV".
Originally Posted by Kalani View Post
OR disabled in the menu, or at least turned all the way down (since some TV's leave a "Mute" notification on screen forever when actually in "mute" mode).
Thank you for your replies.
muting will leave a notification. I will see if I could turn off the speakers on my tv. However should this even be happening? Should I get static from simply plugging the AVR into my tv via hdmi? Seems kind of fish to me.
would a reset help?
post #3130 of 18066
Hi RSXer, try the other HDMI inputs on your tv or try another HDMI cable.
post #3131 of 18066
thanks for your help JChin, I have already tried both, both didn't help. Also tried other outlets thinking might be some sort of interference. Still didn't help.
Might try resetting the microprocessor?
my 2112 is totally brand new!
post #3132 of 18066
bought a AVR-2112CI a few weeks ago and, either we are the ones screwing things up or this thing is defective..... here's the latest problem... I really hope one of you can help.... short of resetting the micro processor idk....
Today I listened to the internet Radio..... the on screen display popped up fine, then switched over to the ps3 to watch some netfix ... turned the system on standby and walked away after I was done.
This evening we watched some netfix again, then decided to switch over and listen to music through the airplay function. I am just learning about this thing.... so please bare with me..... there is no on screen display at all, when I switch to the net/usb, what causes this and how do I fix it ..... what are we doing/not doing right? I have read almost every page of the manual and I find nothing that works anyways
post #3133 of 18066
Hi All,
Finally I received my 3312, and am loving it so far. However, I have a very interesting issue with playing movies via a HDMI connected Mac mini using the Plex media center. Regardless of the video codec, or audio codec in the movie, the movie plays at only around 18 FPS and audio is completely out of sync.
Previously the mac mini was connected via HDMI directly to the TV and things were working perfectly. So I'm kind of taking OSX\\Plex out of the picture here. As nothing has changed on that front.
Can anyone think of anything settings wise, or feature wise that could be causing this ?. Perhaps automatic volume correction ?. Or Audio Sync settings ?. That's all I can think of really..
Many thanks for your help!
post #3134 of 18066
Not familiar with Plex, however, at least one 3311CI owner had an issue getting it to sync properly. You may want to try another media server.
post #3135 of 18066
A couple of owners have mentioned this now. One resolved it by setting the GUI - Net/USB setting (p. 96) to "Always." You could try resetting the microprocessor. Regardless, give Denon CS a call and report it. See if they can replicate it as well.
post #3136 of 18066
Not familiar with Plex, however, at least one 3311CI owner had an issue getting it to sync properly as it was not DLNA certified. You may want to try another media server that is DLNA certified.
Thanks for the reply, but essentially Plex is software installed on the mac mini, that is playing back blu-ray rips located on a NAS. The Video\\Audio is being bitstreamed over HDMI to the receiver. So it's not a DLNA\\streaming issue So it's 'essentially' like I'm playing back a blu-ray from a blu-ray player. If I disconnect the HDMI from the receiver and connect it directly to the TV audio and video is fine.
Audio\\Video from my cable box that is connected to the receiver is fine.
post #3137 of 18066
Yes, I know what it is ... simply meant I was not familiar with it. As suggested, you may want to try a different media server software package.
post #3138 of 18066
Right . Well, I have tried it using VLC as well..and I get the same slow video and out of sync audio .. so is a bit baffling.
post #3139 of 18066
VLC has worked on some older models. Give TwonkyMedia a try.
post #3140 of 18066
So you think that it's actually the way the software is sending out the audio\\video to the receiver, more than the receiver itself ?. I guess I just have to try different combinations to see what works. If nothing does ..then perhaps this receiver just doesnt like the way the mac mini bitstreams audio\\video over HDMI ..
post #3141 of 18066
There are known issues with some HTPC video cards, often resolved by changing video cards.
post #3142 of 18066
Try another hdmi. cable and make sure it is high speed. You could also try a mini plug to composite.
Hdmi does suck but that is what we have to work with.
post #3143 of 18066
further, just to confirm your "suspicions", try going hdmi direct to the TV from a source (ie. bluray player) to ensure that your problem is indeed the receiver and not an "overall" issue in your TV.
post #3144 of 18066
Before you try a microprocessor reset, here's 2 things that worked for me, removing and reseating the HDMI cable at the TV end or unplugging the AVR for a couple of seconds. I get this every few weeks but after a reset it works fine for a while.
When I called Denon about it, they simply asked me try a microprocessor reset or get the AVR replaced.
Microprocessor reset helped but then I got the same thing again a few days later so it did not get rid of the issue.
Please do write to Denon, they might be able to do something about it with a FW update. JD it might help if you can get the message across as well.
post #3145 of 18066
Connected my Blu-Ray to the 2112ci via RCA connection, in addition to the HDMI connection.
Can now play CD's, MP3's from Blu-Ray in Zone 2 (which is my backyard deck).
So, I still don't know if I will be able to play my iTunes library once the Receiver is connected to my Network (not done yet). I've read as much as I can here (and the manual) and I *think* I will be able to do so, I'm just not 100% sure.
post #3146 of 18066
Originally Posted by Enocerous View Post
Is anyone else with a 2112CI having issues connecting to their Win7 Media Server? I've done all of the above listed, plus reset the Denon microprocessor, unplugged it for 15 minutes, gave Win7 allowed shares/permissions, allowed media sharing, and still get "--empty--" when going through Denon Media Server.
Just to let you all know, I finally got streaming working.
From jdsmoothie's suggestion, I installed TVersity (and ffdshow for .flac files).
I even tightened down the security/permissions on the Win7 PC that I opened up to get Windows Media Player to work and TVersity still works.
So I guess Denon and WMP don't get along too well.
Is there any way to get video streamed from PC directly through Denon, or is it audio & pictures only?
post #3147 of 18066
I am.
post #3148 of 18066
It is possible as long as you're not using the AVR as the Airplay client (ie. Airplay via Apple TV will pass video).
post #3149 of 18066
Before I contact Denon, I need to know if this issue is consistant. Are there any other 2112CI (or other networking model) owner's (other than the one's that have already posted about it in this thread) that are having an issue with the Net/USB GUI not displaying after going to another source and then back to Net/USB again?
post #3150 of 18066
Hi All,
Hi.
Sorry, I don't have an answer for you as I just got my 3312CI last week and its my first Denon AVR.
However, I would like to add that I also stream movies from a NAS and so far everything is working perfectly (I stream movies from DVD file structure and hi-def in .MKV container).
My QNAP NAS is connected to my Netgear router. One of the ports on the router then goes to the basement into an 8 port switch. Connected to the switch is my Denon 3312, and PopCorn Hour C200 network media tank. The Popcorn hour outputs audio/video to the 3312 using the 2nd HDMI connection on the 3312. All the network cabling is CAT6 (gigabit) and HDMI is 1.4a (i think).
I have not made any adjustments in the receiver for the video streaming to work.
On a side note, somebody mentioned having problems updating the reciever firmware using a switch. I had no such problem and have done 1 update so far.
