AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 253
post #7561 of 17926
Hey all
I have restarted my effort to identify the "right" refurbished low-to-mid range Denon AVR model, but have found it necessary to comb through various years' "Official" threads to be able to figure out which models have which features.
Am I missing some useful comparison table that has been compiled somewhere? In case I have not, then the attached rough draft may serve as a starting point that could be useful to other "bargain hunters" comparing models from the past couple of years. I've filled in quite a bit, but folks like batpig or jdsmoothie could probably fill in some of the blanks in their sleep.
I have attemped to relate model "families" and within each to show feature progression by year. My selection of features to compare is highly subjective; for instance, I don't yet have a row showing number of HDMI inputs, because as of today I only own 1 device capable of outputting in HDMI!
Comments welcomed.
Thanks and Happy New Year.
Denon Low End AVR Comparo v1.doc 46k . file
post #7562 of 17926
Hi
Just hooked up my 1712. Question about audio for the component connections. I have a game system connected with component cables and I don't know where to connect the audio cables? When setting up the game1 port there is no option for analog audio?
thanks
post #7563 of 17926
Need help with another question? I am using paradigm ADP170 for surrounds and I get an out of phase warning during setup. The speakers are wired correctly.
Should I just skip the error?
post #7564 of 17926
Originally Posted by byeloe View Post
Hi
thanks
Hi byeloe, is the game system audio digital or analog? If analog, use DVD RCA-1 video and DVD analog audio input and rename the Input (Xbox, Wii, etc...).
post #7565 of 17926
If all is connected correctly, just skip.
post #7566 of 17926
Thanks Jchin,
So I won't be able to use the component cables from the game system?
post #7567 of 17926
Thanks Jchin,
I can't see why you can't use component cables, what game system is it?
post #7568 of 17926
It's a gamecube, but there are only 2 component connections, game1 and game2 and during setup they only allow digital audio assignments. I have analog audio only
post #7569 of 17926
^^^ you can not use Game1 and Game2 since there are no Game1 and Game2 analog audio. Use the available name analog audio input thats not taken already by your HDMI sources.
post #7570 of 17926
i connected the audio to the dock input, but now the audio and video are on different inputs. Video on component (RCA 1) and Audio on Dock.
Is it possible to sync these inputs?
post #7571 of 17926
Many would say that the LFE+Main setting (otherwise known as "double bass") produces too much bass and not what the mixer intended.
OK, so this would be more of a personal preference thing than an absolute no-no, based on the perceived sound quality?
post #7572 of 17926
Input Assign
Default ----HDMI----Digital----Component
Dock ------none-----none-------RCA-1--
post #7573 of 17926
Double check your connections first. I was sure I'd connected all of mine correctly when I got the out of phase error for the right surround speaker. Upon checking, sure enough, I some how managed to connect it backward
post #7574 of 17926
There is no analog video component conversion in the 1712 so you will have to hook up the gamecube video directly to TV or run a component cable from your gamecube to avr and assign it to the same source as used for your analog audio. Then run a cable from component out on avr to component in TV.
post #7575 of 17926
My 2312 should arrive Tuesday. I have access to a hard wired internet connection. I am a little nervous about doing a firmware update when the unit tells me it needs it. It is just about the only thing that, if you brick the unit, you are dead in the water. Are there any failsafe things to do to prevent "bricking" and is it a very rare problem?
post #7576 of 17926
Yes, very rare indeed.
post #7577 of 17926
Correct ... as is the case in most instances when folks ask which is the best surround setting as well.
post #7578 of 17926
Originally Posted by JChin View Post
Did you slide a little switch over on your A/V cable to HD? Does it get video if Xbox 360 component cables is connected directly to tv?
Maybe try resetting the Xbox unit itself.
Well....I decided to take defeat and just plugged the xBox directly into the TV via Component. The sounde is going through the Denon via digital connection, so I'll have good sound. I guess there is really no reason not to go directly into the TV unless I was interested in some 3D play, huh? If I get a new xBox, I'll do the HDMI connection. Thanks for the input though....this forum really is a GREAT resource.
post #7579 of 17926
The remote app has quit working suddenly. I get an error that says "connection failed, check unit". I don't know what to check!? I can play Internet radio fine and I can see the unit on my home network, so I don't understand the inability to connect. In fact, even as the error message is displayed on my phone, the receiver will still respond to the volume control. The only other active key is the "quit" button which shuts down the app. Deleting and reinstalling the app did not change the problem. Any ideas?
post #7580 of 17926
Anyone have any idea when the Denon website will be back up? I'm trying to find out some information on bluetooth connectivity on the xx12 and xx11 models? Specifically, if the 3311 has it and if not what models do?
post #7581 of 17926
Try shutting off avr and iPhone and turn on avr first, then your iPhone. If that doesn't work you could try powering down avr and iPhone then reboot your router/modem and restart avr then iPhone.
post #7582 of 17926
Thanks, I've tried shutting off both the AVR and the iPhone, but not in that order. I will try your suggestion and also try rebooting the modem and router. I don't dare interrupt my wife's enjoyment of the Rose Parade just now however!
Another possible clue is that in iTunes, though I can see the AVR 2112CI as a choice for the speakers, I cannot select it. It reverts back to the computer speakers instead. Related? I can control the AVR just fine from my computer remote however, so this seems like an Apple-related problem?
post #7583 of 17926
Originally Posted by Rob100 View Post
Would be very grateful if someone with a 1912 could try this and also a 2312 and 3312 so I can determine if it's my 1912, all 1912's or all xx12's that have this fault.
I have a 2112 and mine was taking forever to connect. I turned the network to standby through the GUI, and now I can turn the receiver on hrough the denon app. It just turns the NIC card in the receiver on, even when the power is off. It always has a connection to the Internet and always has an IP address.
post #7584 of 17926
Originally Posted by Gmtec2 View Post
I have a 2112 and mine was taking forever to connect. I turned the network to standby through the GUI, and now I can turn the receiver on through the denon app. It just turns the NIC card in the receiver on, even when the power is off. It always has a connection to the Internet and always has an IP address.
Hit the stop button below the play button and that should disconnect the Network when you want it off, or turn off Network Standby and your network will shut down when you power down avr.
post #7585 of 17926
No ... use ARC when you want to pass audio from the Sammy to the AVR and turn it OFF when you're not using it, although you could also use Airplay to stream from the iMac directly to the AVR as well.
I'm also trying to get the audio from digital video stream via my Samsung TV to play through the AVR speakers (I expected the ARC via the TV input on the AVR to do the trick...). But no sound. How do I turn ARC on/off on my 2312 as per the above reply?
Andrew
post #7586 of 17926
Andrew
Hi Andrew, set "HDMI Control" to ON (see page 1, post #3, Features 5e).
Menu -> System Setup -> HDMI Setup
post #7587 of 17926
Ok, got the app working again. Shutting everything off and rebooting (including the router) allowed me to re-enter the ip address, which seems to have done the trick. Thanks.
post #7588 of 17926
Denon AVRs do not support bluetooth connectivity.
post #7589 of 17926
Hi experts and friends-
I have an AVR 1912 and using the ipod with USB I thought that I can get audio out of all of the 5.1 speakers but only can out of the fronts and center. Am I doing something wrong with the set up or is that the only sound config I can get??
Thx y'all to this amateur!
post #7590 of 17926
You can get simulated 5.1 using either DD PLII - Cinema or Music.
