AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 283
post #8461 of 18065
Originally Posted by enzymez View Post
Just received my 2112ci this week, and I need help connecting my sub. This is my first audio system.
I don't quite understand because from the receiver, the subwoofer pre-out has one jack, but on the sub there are two jacks in the LINE IN, right & left(LFE), looks like RCA too. The sub is a Klipsch KSW10.
Plug it into the left(LFE) input, it is RCA.
post #8462 of 18065
Originally Posted by Hilfiger1975 View Post
Would i need a sub EQ if i buy a Rythmik FV12? Doesn't the Rythmik offer that already on the amp?
If the Rythmik comes with it's own EQ, it would be certainly be better if using an Audyssey 2EQ AVR.
post #8463 of 18065
Originally Posted by drWaLLs View Post
Follow up question - can I install separate speakers where this secondary TV is and use zone 2 for audio?
Example - TV outside with two speakers hooked to zone 2, HDMI out to both TVs, receiver set to amp - not sure if I'm explaining it well.
Yes, this would work with the limitation that if both TVs are not the same resolution, the video signal to both TVs would be reduced to the TV with the lower resolution, and the video source would also have to be connected to the AVR with analog cables in order to pass the audio to Zone 2.
post #8464 of 18065
Originally Posted by grinny View Post
Actually, I can get them both to turn off, but I can't get them both to turn back on again (the AVR won't come back on).
I only see a couple workarounds:
1) program the remote to send separate on/off signals to both devices (which if the remote loses line-of-sight can get them out of sync).
2) Plug Tivo into TV via HDMI and have the Tivo audio reach the AVR via ARC, so that if the TV is off, the AVR can't get any sound from the Tivo. Probably the best (only?) option.
Ensure that HDMI Control is set to ON on the AVR. Although this setting generally always works to turn the TV/AVR combo off (as noted in the Owner's manual), it doesn't always work to turn the TV/AVR both back ON again. In addition to the work arounds you suggest, a Harmony remote would also be an option as well as contributing to the WAF.
post #8465 of 18065
Originally Posted by Nethawk View Post
I was hoping to use the 3312's dual HDMI out ports for video/audio to main HT display and that my office. If I understand jdsmoothie's response to a previous question, this will not be possible as I would naturally run HDMI 1 audio through the AMP and HDMI 2 audio to the second display. Is my understanding correct?
If so, bummer! Since these are on separate floors of the house an HDMI switch would be a big inconvenience. Is this simply a silly oversight or a stipulation of HDMI? Are there AVR that support separate audio configurations of second HDMI output? I see no easy workaround.
Thanks in advance, and apologies if this has been covered.
I'm confused as why using a switch is a "big inconvenience" considering that instead of plugging the HDMI from the office TV into the back of the AVR you simply have to plug it into the switch which is likely located only a few feet away from the AVR?
AFAIK, there are no AVRs that support separate audio configurations to the dual HDMI Monitor Outputs. See my post #8474 above for another possible option.
post #8466 of 18065
As noted in the KSW10 Owner's manual, plug the cable from the AVR's sub preout into the (right) RCA input on the sub labeled "L(LFE)". Also as noted in the manual, only if the sub is not able to receive a signal via this configuration would you want to connect a "Y" RCA splitter cable to the AVR and then connect two cables to each of the "R" and "L(LFE)" RCA inputs on the sub.
post #8467 of 18065
Originally Posted by Dr. Crash View Post
Does Electronic Expo still offer phone deals on the Denons like the $369-$399 2112? If so, any specific extension number to ask for?
It doesn't matter who you speak with at EE, just tell the sales rep you saw them advertised on AVS Forum and ask what their best price is on whichever model you are interested in purchasing. Note the prices can change from week to week depending on what their inventory situation is that week.
post #8468 of 18065
Originally Posted by nikivan View Post
After updating to the latest firmware today only HDMI 1 works. I am getting black screen with the other HDMI inputs. I've double-checked the input settings are correct. The update routine did not show any errors. Any suggestions how to troubleshoot this?
When having stange issues with the AVR, the first troubleshooting step would be to do a "soft reset" and unplug the AVR for 10 minutes. If still no joy, and if you haven't done so already, SAVE the config file to a PC (p. 68 Web Control) and then reset the microprocessor (p. 129). If that doesn't resolve the issue, then give Denon CSR a call and report your issue.
post #8469 of 18065
Hello,
Maybe more digging through this excellent forum would turn up an answer, but I am running out of time so please excuse my ignorance.
Just got the 1712. Have a Tivo plugged into it via HDMI (though the Tivo might as well be any cable box), and the receiver plugged into a Samsung LED via HDMI. I've been trying all HDMI control options I can find using the guide at the start of this thread, but I can't find a configuration that will turn off the TV and the AVR together (if the AVR stays on it will continue to play the audio from the Tivo regardless if the TV is on). Actually, I can get them both to turn off, but I can't get them both to turn back on again (the AVR won't come back on).
Wondering if there is some other combination of settings I am missing?
Funny with all these cool features, the one that bugs me the most is the on/off button.
I think you would enjoy and benefit from purchasing a harmony universal remote. It will program activities which will turn on and off and switch inputs etc... for several sources although you will still have to point it towards the sources some what carefully as to not to get it, out of sync.
Edit; JD posted 7 before I got this one out.
post #8470 of 18065
New to AVR's, finding my way...
My 1612 sometimes, I can't exactly reproduce it, has to be turned off and on to get audio. The power light will be a solid green but no audio. Another thing that just happened last night was that all the HD content on my DVR tuner was only coming through as 2.0 PCM. I again had to cycle power on the AVR to get the 5.1 signal. Anybody have a general thought as to what may be going on here?
I continue to have HDMI-control issues, I really want to control the volume of the AVR via the DVR remote, set to the TV as I can't get the remote to work the AVR directly. Can HDMI-control adjust the AVR volume from the TV back up to the AVR?
Thanks again.
post #8471 of 18065
Unfortunately HDMI connections are often more trouble then they're worth. If the DVR is passing only PCM 2.0 to the AVR, then this is an issue with your DVR, not the AVR; however, note that although a TV show might advertise being broadcast in DD 5.1, the local station may choose to broadcast in only PCM 2.0. Try resetting your DVR (power OFF/ON). If you have the HDMI-CEC feature set correctly on both your TV and the AVR and are still unable to control the AVR's volume with your TV remote, your best configuration may be to connect the DVR HDMI directly to the TV with optical from the DVR to the AVR for surround audio.
post #8472 of 18065
Originally Posted by ditrasetman View Post
I posted this as a separate thread, but really
The menus are crisp and look good on my 2112ci. However, when I am in the USB/Ipod function on the unit, the on screen display is a tiny bit fuzzy/blurry - it almost looks like it has a small amount of flicker to it. But, like I said above, the rest of the on screen displays and menus are crisp and clear. Is this normal?
The Net/USB seems to be at a fairly low resolution, my TV reports a resolution of 720 x 480 while using Net/USB, Tuner resolution is 1280 x 720 and 1920 x 1080 for my HTPC and Disc player.
post #8473 of 18065
Thanks Jeff, I'll call and complain too. Might help with a real fix, concerning the GUI net video not showing up.
post #8474 of 18065
Thanks for the suggestion. I was afraid of getting the Harmony remote option (since I love my Tivo remote), but I will consider it more. If the Harmony is smart enough to avoid getting the power states of multiple units out of sync, that might be really nice.
Actually, I think I can program my Tivo Slide remote to turn on two units together (TV+AVR), and as long as the HDMI control always will turn both units off, the chance of them getting out of sync is not so high I guess.
Do other brands of receivers have the same issue? I would guess they do, since it appears to be a general HDMI control limitation. But I will research what brands might work best with Samsung TVs just in case.
But maybe I will just use ARC since I have plenty of inputs (though it seems crazy not to plug all the units into the 'receiver', which should be best at receiving. I can plug Tivo & BD into TV, and use ARC to connect TV to AVR. My only fear with that is if there can be different audio sync delay for Tivo vs. BD. I've had some audio sync problems before, but it wasn't clear to me if it was a problem with the av source or with my connection. So far as I have read, the audio sync should always be fixed, and I guess it should be if all audio reaches AVR by ARC. But if I plugged the BD into AVR directly, would that still be true? I am not certain.
post #8475 of 18065
Thanks again.
I think I saw you post before that you have a Panny ST30? Did you change the audio settings on the Panny to "home theater" and turn TV speakers off? I have an ST30 & AVR1612 and the HDMI-CTL works perfectly. They go on/off together and I can control AVR volume with any remote that can control the TV.
post #8476 of 18065
Ok, so it is normal for the NET/USB menu to look ugly? It is just fuzzy, and low res - and my 60" tv makes it look even worse.
post #8477 of 18065
The problem with connecting Tivo & BD to the TV and using ARC is that you almost certainly will only get 2.0 stereo output that way. Of course, you could separately connect audio from them to the AVR.
Sammy's Anynet+ seems to have issues "playing nice" with other equipment. By any chance does it have separate auto-on/auto-off controls? Just thinking maybe that's the reason you can't get TV & AVR to turn on together.
post #8478 of 18065
It looks low res because it IS low res (standard def, not HD). It looks fuzzy because you're enlarging a low res screen to 60".
post #8479 of 18065
Originally Posted by J e f f View Post
Update.... I just got off the phone with Denon and was told that there is no way it’s a hardware issue with the missing net/usb video, said it was totally a software thing and they are working on a fix. So I have decided to keep my 2112ci, Love this thing other than this one issue.
Do you guys with the "missing GUI on NET/USB source" still have this issue with the latest firmware update from a week or so ago installed?
post #8480 of 18065
I have the GUI issue after the update.
post #8481 of 18065
Not fixed after the last update for me neither.
post #8482 of 18065
I have the latest firmware update and I still have the problem. Works fine a time or two if I unplug, even for a second of unplugging.
post #8483 of 18065
Someone here mentioned after the latest update, only one hdmi works on his Denon. Anyone else here having same problem or new problem with the latest firmware? Does the new firmware fix some of the problem seen before?
post #8484 of 18065
Originally Posted by Kalani View Post
YPAO and MCACC are the Yamaha and Pioneer flavors.
Most consider Audyssey to be the best, particularly the higher end XT and XT32 varieties.
If you prefer the sound of the Yamaha or Pioneer room correction, however, SOME of the advantage of Audyssey could be restored by using some special hardware to EQ your sub separately, since those don't EQ the sub and Audyssey does. (Actually I think someone said that the highest level version of YPAO on the flagship AVR does EQ the sub, but I haven't verified that.)
Need some clarification on this, but I could have sworn there was a thread on here where someone mentioned that he had one of those particular receivers with that version of YPAO ( the top two Aventage models). Problem he experienced was that it was only EQ'ing down to about 40 or 50 hz AND was cutting off the sound signal below that. Not just ignoring the extreme lower frequency signal but actually butchering it off.
post #8485 of 18065
Probably more info in the Yammy threads. I only own Denon, ATM, with no plans to change for the next 5+ years, so I don't need to know all the specifics. I just recall someone piping up when I said that of the three big one, only Audyssey EQ'd the subs. May even have been in this thread.
post #8486 of 18065
It was across many channels, all 2.0 PCM. Cycling the AVR brought it back to 5.1. I am presuming the AVR has no effect on what the DVR is putting out, so the AVR was mishandling the signal?
LOL, I went through it again, didn't see anything different, and all of a sudden the volume controls started getting from the TV to AVR. Go figure.
Thanks for the response.
post #8487 of 18065
Yes here as well.
post #8488 of 18065
Yes, that's me. I had done that, and was getting the "speakers off" message on the TV. After reading jdsmoothie's response I revisited the menus again and I don't know, but it then started working. I get the "home theater" volume indicator on the bottom now (although I'd really like to hide that), so it's working just fine, as you indicate it should.
After all this I am seriously considering a universal remote. Some of the house members are complaining bitterly about this. Luddites.
post #8489 of 18065
Originally Posted by jakeroux View Post
Yes here as well.
Thanks for the updates guys ... I asked because I was originally told the last update may have resolved the issue, otherwise Denon NJ is telling me there is no firmware fix in the works. So if anyone has spoken to a Denon CSR that indicated otherwise or if you have a case # regarding this issue, please PM the information to me so I can follow up. Thanks.
post #8490 of 18065
Can someone (preferably someone who has on) confirm that the Denon 1712 does have Audyssey MultEq XT? According to the Denon 1712 Web Page it only has MultEq (in the summary), and it also has XT (in the details). Which one is true?
If it has the XT, it seems like a no brainer for me as I don't need the networking (I have enough networked devices). I have two questions then, though:
- How would I apply a firmware update to the 1712 if needed?
- Does the 2112's RS232C connection offer much better automation possibilities than controlling the 1712 through an iTach and an IR emitter?
- What would the 2112's stored profiles allow me to do that I may regret not having later?
