AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 312
post #9331 of 18066
JD, thanks for your help the past two days. Now all of my hdmi devices aren't negotiating with the 2312. Think its fair to give the Denon another chance and return the one I purchased.
I found a solution to the "bass too loud" issue. There is a lpf frequency volume setting that looks like I can tweak while keeping audyssey active.
post #9332 of 18066
Originally Posted by spager View Post
It sounds like an Hdmi issue. Since it has been working properly and it happens on several inputs it is probably your hdmi cable to your tv. If it happens again here are a few remedies to try.
1. Unplug avr cable to tv on both ends and replug it in making sure it is in securely.
2. Swap out hdmi cable to tv.
3. Try a complete hdmi reset that is on page 1, post 3, no. 12i.
4. Do a microprocessor reset.
After I unplugged the receiver from the power and plugged it back in everything was fine. Weird... ;(
Sometimes the AVR processor just hiccups (as does your PC) and requires a soft reset (unplugging for a few minutes). If you find you're having to do it on a regular basis, then do a full microprocessor reset (p. 149).
This is most certainly the first receiver I've had that needed unplugging. All my previous receivers have been Onkyos. Hopefully this doesn't become a regular occurrence. Thanks!
post #9333 of 18066
Originally Posted by tanishq02 View Post
On my SUB, I have 2 settings Phase (0 or 180) and BASS Boost (0, +6 and +12db). I know I need to have Phase at 0 before doing AUTO SETUP. What should I set for BASS Boost? Can I change BASS boost after AUTO SETUP, if I feel BASS is less and will it have any effect on Audyssey?
Leave the BASS boost setting at 0 as the AVR is doing the bass management. After AUTO SETUP, use the remote control button to boost the sub level if desired.
post #9334 of 18066
If you are referring to the LPF for LFE setting, that should be left at the factory default setting of 120hz. If resetting the microprocessor doesn't resolve the issue, then exchange it.
post #9335 of 18066
So, are you saying increasing BASS boost on the SUB and increasing from AVR will give me same results?
post #9336 of 18066
No, I found a setting where you can specify the levels of the SPL effects. I'll look into it further. Thanks will try the Micro reset.
post #9337 of 18066
Nevermind, I performed the Microprocessor reset the moment I unboxed the receiver.
The setting that I think would lower the LFE bass levels (ie: the BOOOOM!) is:
Audio Adjust> LFE
Adjust the low-frequency
effects level (LFE).
–10dB – 0dB
For proper playback of the different sources, we recommend setting
to the values below.
• Dolby Digital sources : “0dB”
• DTS movie sources : “0dB”
• DTS music sources : “–10dB”
post #9338 of 18066
Well after all the great info here especially from batpig and JDsmoothie and the prompt responses, I am off and sailing with my 1912. As can be attested by my neighbor at my door Friday night asking me to turn it down....
Now the fine tuning will begin as I dig more into the features and connectivity and more advanced features....
I did discover by accident that on the media server page that my wife's iMac was listed via an application called Eye TV. I drilled in and was able to get into her iTunes so I downloaded a trial of EyeConnect (not Eye TV but same company) for myself. The website said that if you do not purchase after the 30 days only the audio will be available. Hmmmm....Which is what I would want anyway....duh?
Anyone here used this who is on a Mac?
Also-
A disclaimer on their site advised that any purchases from iTuns will not be available to stream on EyeConnect due to copyright issues with iTunes. Again any experience with this?
post #9339 of 18066
Edit: On a brighter note, and yes, it's been a long time coming for sure ..... the new XX13 models are apparently all going to be firmware updatable via a USB jack.
Perhaps one of you fine gentlemen can create an XX13 speculation thread. Apologies if there is one already, I looked but didn't find it.
post #9340 of 18066
Hi Phantom Gremlin, something like this thread "When do the 2013 Denon's come out? Any new features we should expect?"
post #9341 of 18066
Nope. I'm saying to ONLY make the adjustment on the AVR and NOT on the sub, otherwise Audyssey won't be aware of the changes made when done on the sub itself.
post #9342 of 18066
3312ci
Every time I turn it on, it needs to resetup its network connections. They work fine, I have all the access to my LAN, Pandora, etc., but it never "remembers" its connection.
How do I avoid having this 2-3 minute delay between power on and music access?
Ken
post #9343 of 18066
So it looks like I have to perform the "run around" with Denon, and return the device to them, rather than the authorized dealer if its defective.
They are asking me to perform a "Reverse HDMI Handshake"
post #9344 of 18066
Originally Posted by c3k View Post
3312ci
Ken
Do you have a wired or wireless connection? Have you tried resetting your router?
post #9345 of 18066
Why? Most resellers have a 15-30 day return period for defective items. Who did you purchase from? Contact the reseller for return/exchange.
post #9346 of 18066
is there a big difference between raising the channel level for the sub on the avr vs manually raising the volume on the back of the sub? i want to raise it but not sure which one
post #9347 of 18066
Yes, there is ... make adjustments on the AVR so Audyssey can adjust for the changes.
post #9348 of 18066
I have a new AVR 2312CI but have an issue I can't seen to figure out. On every HDMI video source (Cable, Roku, PS3, etc) except one I get an on-screen display of volume when I change it via the remote.
The strange one is a Mac Mini running Plex also via HDMI. This input never shows the volume on-screen. Also, when the Mac Mini is the source and I bring up the AVR's menu, I do not see the menu overlaid on top of the video like I do on every other HDMI channel.
Any clues to why?
post #9349 of 18066
What resolution is the mini outputting and what is the display reporting as its input resolution? How are the upscaling settings configured...
post #9350 of 18066
This particular company allows return of defective merchandise within 30 days. When I inquired about possibly returning and was directed to Denon. I will not state the companies name as its a very popular one amongst these boards. Shipping isn't refundable so we're looking at $60 if I go that route.
post #9351 of 18066
The mini is outputting @ 720p. My cable box, for example is outputting 1080i. The HDMI info section on the AVR shows 1080i --> 1080i when the cable is the active source, but shows -- / -- when the mini is the source.
Upscale is set to analog only (an old PS2 is the only analog source).
post #9352 of 18066
It's a wired connection into switch which is connected to the cable modem.
The IP address stays the same, as it should, with a hard-wired switch. Would changing the 3312 network menu from DHCP to static resolve this?
post #9353 of 18066
The mini apparently is outputting a resolution Denon doesn't like all that much... can't overlay. I would play with the Mac's resolution to see if that helps and for the fun of it have Denon scale the image to 1080p.
post #9354 of 18066
I had done a lot of research and decided on the avr1611. However that is no longer available. Is the 1712 a comparable product and what would I be gaining or losing by going with the 1712? Thanks much
post #9355 of 18066
Gain: better version of Audyssey: MultEQ XT; GUI; GUI overlay on 2D video
Lose: Analog ---> HDMI conversion
Review post #2 on page 1 of this thread for a comparison of the various models. Then review posts #3-6 for more helpful info.
post #9356 of 18066
Thanks....I had read through those posts as well as several pages deep. Just wanting to know if the 1712 is as reliable as the 1611 appeared to be. I have seen a lot if positive feedback on the 1611 but not a lot of posts in regards to the 1712. So it made me question my decision....
post #9357 of 18066
Electronics Expo still has them in stock and is one of the most recommended resellers in this thread, but you must "call" them for their best price.
http://www.electronics-expo.com/deno...p-and-3d-black
post #9358 of 18066
Using my 3312, I never had a problem scaling my AppleTV2's 720p output to 1080i for my CRT-based HDTV. Volume overlay and such was fine.
post #9359 of 18066
in reply to....JD
Electronic expired us the one that told me they are out of stick as of 5 pm ET today.
Any more thoughts in the 1712?
post #9360 of 18066
Sorry that's electronic expo...not expired
