Correct it's the way the amp is made. The volume will turn on what you selected for power on level, but will follow what volume you set for that particular input when you change to other inputs.
There is a Source Level you can use in the Input Setup that can help level out volumes per input. I believe all models have this option.
Originally Posted by saj2001ind
if you are changing source using quick select then the volume will reset to what is stored in that quick select, if you dont want the volume to change then use select source button and from there select ur source this way the volumes will not change just the source will change
Thanks guys, I will change inputs directly not by quick select.
You can have different volume levels (or the same) for different inputs using the Quick Select buttons. While you are on the input make the necessary changes that you prefer in your case have volume to -40 or what ever and then hold down the Quick Select button for a few seconds until memory appears on your screen and there you go. New settings when you press that particular Quick Select.
Try setting the Reference Level Offset to 10db for your cable/sat box source which should improve the center channel dialog (also referenced in post #3 item 12(f) in the Troubleshooting section linked in my sig). You can also simply bump up the center channel volume a few db using the remote control button.
Multi Channel stereo simply replicates the FL/FR stereo to the other surround speakers, which is generally what folks with hearing problems prefer as it places the dialog much closer to their ears via the "side" surround speakers, however, you do of course lose the surround effect of DD 5.1 by doing so.
Thank you all so much for your advice. I changed the reference level to 10dB as suggested -and it did help- but more importantly, I re-ran the Audyssey setup after the the tweeter swap-out (the original was blown). I had replaced it before my post but hadn't re-calibrated, and this by far made the biggest improvement.
WOW!! I have never heard my speakers sound this good before (got them in 2003). This receiver is amazing, especially the Audyssey software. Dolby TrueHD and DTS-MA are ridiculous. I'm going to run through evey episode of Star Wars to indulge in some audio porn.
Again, thanks for all your guys' help. You all rock.
Is anyone aware of any HDMI handshake issues between the 2312ci and the TC-P60ST30 or other recent Panasonic Plasmas? I just got the 2312, which I love, but it has major HDMI handshake issues with my old Panasonic 50" plasma. I've tested it with another TV so I know it's not the receiver. The TV is about 7 years old and was one of their first models with HDMI so I'm not that surprised there are handshake issues.
I've been planning to get a new set with 1080P anyways, and this is the perfect excuse. I found a great deal locally on the Panasonic TC-P60ST30 and figured I would check on this thread before I pulled the trigger.
Thanks in advance for any help on this.
Denon AVRs generally don't have issues with the newer TVs .. rather only some cable/sat boxes.
the only benefit of the Quick Select is that it takes a "snapshot" of your receiver memorizing all settings (like Audyssey setings, Input Mode, channel levels, master volume, etc) at the time of the snapshot. So if you want to be able to quickly recall a specific state(s), then it would be useful.
The Quick Select works very well with a Harmony remote that is activity based.
I have different settings for "Watch movie", "Listen to SACD", "Watch cable" and "Watch movie midnight" activities on my Harmony 900 remote.
First and foremost, thanks to all for this ever amazing thread, with oh so much help and knowledge. It has been amazing, yet overwhelming.
Just last night, I finally got my 2112 hooked up and running. It actually went pretty smooth, again, thanks to a little prework and research here. I have stumbled on one issue, which was with the "bd" hdmi input after hooking up my Panny DMP210. I was getting screen flickers and a little white noise. I first tried switching out the hdmi cable, with the same results. I then went to the "DVD" hdmi input, and still the same issues. Finally, I was able to remove the issue on the "Game 1" hdmi input.
My question is, are those two inputs bad? What are the chances they'll work correctly with another device? I'm still within my 30 day return window. Is this worth looking into a return? Thanks.
Hi jedorf, try going into BD player HDMI Setup menu and turn "Deep Color Output" to "off'".
I have a quick couple of questions about my AVR 1612. I have an old game i want to play (it runs fine on my modern computer). The problem is that I run both my video and audio through HDMI (from the video card) to my 1612 and then back to my LCD monitor. Apparently this old game has issues with the digital audio or something related as I get no sound whatsoever out of it. Now, if my 1612 can do what I want, maybe I can get around this. I have an integrated audio chipset on my motherboard that i use for the microphone. I took a standard 3.5mm to RCA cable and connected the front LR speakers to the video aux RCA connectors on the front of the 1612. But I can see no way to maintain the video.
Basically what I need is to be able to send my video/audio from my computer through the HDMI (currently going to HDMI 4) but be able to swap the audio out for the RCA connectors on the front when im playing this game and still leave the video coming from the HDMI. This would seem to be possible, I just don't know how to do it.
One other question as well, I have never been able to get the GUI to work on the LCD screen. It's never once passed the gui info to the monitor from the 1612. Am I doing something wrong? (this is completely unrelated to my game audio issue) Is it possible my LCD monitor (which has HDMI in) doesn't support something that is required for the GUI to work?
Analog audio inputs are NOT assignable, while the HDMI inputs ARE assignable, therefore "assign" HDMI4 to the V. Aux source and change the INPUT MODE for that source to "Analog" and you should be good to go. If the GUI doesn't show up for any source, then try resetting the microprocessor (p. 94).
Historically, the HDMI inputs have not been identical, although JChin's suggestion may very well resolve the issue for you.
Ok the assigning works, thanks! I'll just have to remember to switch it back after I'm done playing the game. After reading a bit more, it seems the GUI is displayed in 480i. I think that is problem. I doubt my 24" monitor works at 480i.
I returned the Denon 2312ci, and the new one works fine with all of devices except for the Cable Box (willing to accept this as a known issue). Would buying a HDMI "Switcher" help? Otherwise i'm going with the optical cable.
I also had a issue with my WDTV where signal was fine until I started a Netflix movie, then it went to white/black flashing. A reboot fixed it but I have to look into The WDTV's settings.
Thanks ! That's exactly what I wanted to do. So happy I asked here !
My setup is Denon 1712+Samsung 6 Series LCD TV with XBOX360, PS3 and Popcorn Hour A200 all connected via HDMI to receiver. Bought AVR in September 2011 and before last month everything was smooth. First I noticed problems when played one particular game on PS3 (Twisted Metal Demo) for whatever reason TV turned off when in the game - other games played just fine. So everytime I started the game and tried to enter the options menu - boom - TV is off. I turned off all HDMI controls in PS3 and in AVR, still same thing. Then probably a week ago while was watching PCH when resolution switched (say from 720p to 1080p) screen started blinking and the only way to fix it was to switch sources couple times. So I decided maybe PCH acts funny, but then yesterday I got same thing when playing PS3 - I played COD Black Ops - and in menu everything was fine but when round started - screen was blinking (or vice versa). Tried to power off the receiver and disconnect power cable for 10 minutes and also resetting microprocessor - still no luck. Also tried to switch cables to all inputs and tv hdmi ports as well.
Is there anything else I can do or send out unit to repair is the way to go? Also there is a service center close to me according to denon website, do I have to submit a ticket first or I can just schedule an appointment at service center and bring my unit and original receipt?
Why do i hear the radio tuner in the background on my Denon 2112 when
i am listinening to music or watching a movie this is when i pause the movie
or music on the CD/DVD
Thanks for replies.
Have you tested whether these issues occur when the sources are connected directly to the TV to rule out the TV being the issue?
Looking to upgrade the sound on my Panasonic plasma.
Just ordered B&W 685s and HTM62. After following this thread, it looks like 2112 would be the way to go.
The question is whether to buy now (assuming I can get a good deal on the 2112) or wait a month or two to see what the 2012 receivers will bring.
Of course, the new models probably won't be discounted right away or as much if at all.
Any sense on what changes might come to the midrange and whether they might be worth waiting for?
The 2112CI has been discounted up to 30%+ or more by some authorized resellers including AV Science, Electronics Expo, and J&R ever since it was first released last summer. The new 2013 models will be announced in April and released starting May/June.
thanks in advance for your reply
This issue gets reported from time to time. Try resetting the microprocessor (p. 129) to see if that resolves the issue.
JD: My new Denon is working fairly well. I ended up using an optical cable to connect my Cable box. I still get occasional snow flashing errors with the PS3 and WDTV. Switching inputs and back sometimes resolves the flashing issue so I guess I'll just do that.
Good to hear. Can't help you with the WDTV, but for the PS3, make sure the Deep Color Output is set to OFF to prevent issues that setting may cause.
Hello all. I having an issue with my AVR 2112ci dropping the video signal fairly often. Was wondering if this is happening to other owners? Before explaining the issue, here is my current setup:
[list][*]2010 Samsung TV (with Anynet turned off)[*]Verison Fios DVR (Cisco model) [*]Denon AVR 2112ci[*]Samsund BlueRay (with Anynet turned off)[list]
*All connections are with high speed HDMI and are under ten foot in length.
The issue is that from time to time (twice in the last 7 days), I lose video signal. It happens especially when listening to Pandora through the Blueray. This occurs by the tv simply dropping the video and showing message "no signal. Check connections", but the audio is still playing? After this, I can not get the video to show again. Audio on Cablebox and BlueRay both work. I unplug all devices for 15 mins and try powering back up and then after about 30 mins of fussing, something finally clicks and the video signal is back? I have also tried reset the microprocessor to fix the issue. The process is cumbersone and frustrating to say the least.
I have had nothing but issues with this Denon unit dropping signals since purchase back in July. When it works properly, it is fantastic. But the above issue has become a burden. Any help or advice is greatly appreciated. Thanks everyone for reading.
