AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 317
post #9481 of 18957
You can stream video and photos over AirPlay only to AppleTV 2s.
post #9482 of 18957
Is it because of the Denon firmware that videos and photos cannont be streamed over Airplay? Will the future Denon firmware upgrade will enable this? I like the mirroring of iphone/ipad on TV but the cable costs USD43 while the AppleTV2 costs USD150 as I reside in Asia.
post #9483 of 18957
Originally Posted by lou99 View Post
Thanks - Is that the only setting to look out for?
Yes ... it's the only one that can cause video issues with some displays.
post #9484 of 18957
Originally Posted by var1abl3 View Post
^ Only audio is supported over Airplay on Denon AVRs.
... as well as Marantz and Pioneer AVRs.
Nope ... it's because Apple hasn't licensed the above mfr's to support video, although if/when Apple does allow it, there is likely to be no firmware upgrade, rather only newer models would have the feature implemented.
post #9485 of 18957
If Apple has ambitions in TV as rumored, they may never license AirPlay streaming of video to 3rd parties.
post #9486 of 18957
Speaking of Airplay, anyone here having problem with Airplay icon NOT showing on iphone music?
post #9487 of 18957
I remember reading here but can't find it. The serial number is linked to manufacture date. How to interprete it (example serial number 111XXXXXX)? Thanks.
post #9488 of 18957
This is usually resolved by turning the iPhone OFF/ON.
The first digit is the year and the next two are the month ... so in your given example the AVR would have been mfr'd in Nov 2011.
post #9489 of 18957
Always can count on you JD. Thanks. My new 3312 has 111 November 2011 MFR date.
post #9490 of 18957
Originally Posted by av_freek View Post
Is anyone aware of any HDMI handshake issues between the 2312ci and the TC-P60ST30 or other recent Panasonic Plasmas? I just got the 2312, which I love, but it has major HDMI handshake issues with my old Panasonic 50" plasma. I've tested it with another TV so I know it's not the receiver. The TV is about 7 years old and was one of their first models with HDMI so I'm not that surprised there are handshake issues.
I've been planning to get a new set with 1080P anyways, and this is the perfect excuse. I found a great deal locally on the Panasonic TC-P60ST30 and figured I would check on this thread before I pulled the trigger.
Thanks in advance for any help on this.
I've got a 2112CI connected to the same TV and there are no handshake issues that I've found. Had to change the settings for the HDMI control, and make sure the HDMI cables were connected to the correct respective jacks on the 2112 and Panny, to get the ARC working, but it's been solid overall.
post #9491 of 18957
I have a new denon 2112 and presently stream audio on my computer via a wireless bridge but would also like to stream videos. I was considering purchasing Apple TV and returning by wireless bridge but I do not know how to connect Apple TV to my system. The apple sales rep told me to connect apple tv directly to my TV and then use the monitor output connections to connect the sound to the receiver. I have a limitation with my Pioneer PD-5080 plasma tv as it does not allow the output function on digital inputs from HDMI or Component connections. Apple TV only has HDMI and component connections. Any ideas on how to connect Apple TV to my system or any other ideas in how to stream video would be appreciated?
post #9492 of 18957
The ATV (HDMI) can be connected directly to the AVR as another HDMI video source. You can then stream video to it using the ATV Airplay feature.
post #9493 of 18957
@ gfran
I've got the Apple TV connected to the DVD HDMI input on my 1611. Works like a champ.
post #9494 of 18957
if your prime aim is to stream then get WD Live it has better codec support, plays almost all formats and it can be connected to ur AVR directly, apply tv will give you a lot of problems
post #9495 of 18957
Installed the 2112Ci this weekend to replace my 4 years old Pioneer Elite. I thought it was a downgrade in exchange for HDMI 1.4a support but as it turns out, My setup sounds better with the Denon thanks to Audysee MultiEQ XT and DynEQ. I am impressed with the overall sound quality.
post #9496 of 18957
I am looking for pics of the GUI with the 2312. Specifically the channel level adjustment. Dose the menu entirely block out the screen or is it translucent enough to make adjustments "on the fly" during shows?
I have the 1910 which doesn't have hdmi GUI so i can adjust the center channel or sub during movies on the receiver screen.
post #9497 of 18957
not sure if this is a silly question but say if I want to use my ps3 which is linked to the game HDMI on the 1912 input do I have to have the denon turned on to view it on the tv or is there a way to have a passthrough so I can just see it on tv without having the denon turned on?
post #9498 of 18957
if you are concerned about the wife yelling at you for tweaking while she is trying to watch then it will be an issue, the GUI does block out most of the screen.
the best bet if you want stealth changes is to use your laptop or smartphone/table to make channel level changes via the web browser interface.
post #9499 of 18957
see here: http://batpigworld.com/fadq.html#hdmi
post #9500 of 18957
Smart phone web browser interface? You just made so happy I think i need a smoke!
Sold!
Thanks batpig, you rock
post #9501 of 18957
The Apple sales rep was a moron, then.
Just connect HDMI from the AppleTV to your AVR, same way you connected your Blu-ray player (and probably your satellite box). ATV > HDMI > AVR > HDMI > TV.
The ONLY way to stream video via AirPlay, if that is your goal, is via the AppleTV. At this point, at least. Apple has not licensed AirPlay VIDEO for any other company, just AirPlay Audio.
If you're just pushing video in various formats from your computer to your AVR/TV, then saj2001ind is correct that there are other devices that support more file types (although not via AirPlay). And AppleTV's interface is truly a thing of beauty... others have a LOT of catching up to do in that regard. He's also wrong about "issues" with the AppleTV, however, it worked fabulously, within it's feature set. If you want features that aren't included in it's feature set, that's not an "issue" with the AppleTV, that's an "issue" with the person who bought the wrong device to accomplish their goals.
post #9502 of 18957
True, although other devices also do this (and better that the WD unit, IMO), such as the Roku, and everything can be connected to the AVR directly, that's not some special unique WD feature.
Wrong.
post #9503 of 18957
Hi,
I have connected my slim PS3 thru an HDMI cable to my Denon 1912. I have the aduio output on ps3 to bit stream. for some reason, when the front panel on the denon reads DOLBY, I am not getting any sound / effects on my rear speakers. can somebody please let me know If I need to do something on my receiver.
Regards
Swt
post #9504 of 18957
check the disk menu and ensure you are playing a multichannel track...
the avr is passive, it only takes what it gets...
post #9505 of 18957
I own and use both Apple Tv2 and WD live. Apple Tv has a really nice interface for Music and Movies but as Apple does, it imposes their proprietary codecs so if you have a library or thinking of it that isn't in their codecs it renders it nearly useless for Video.
Now WD live has a ton of codecs and plays nearly everything and has great interface for Video. That being said the interface for Music is terrible with no really way to make a playlist on the fly. This is why I use both.
My advice is unless you have iTunes Movies (using their codecs) don't bother with the Apple Tv unless you really want a nicer interface for Music.
For Video non Apple you will need a different 3rd party hardware which there are many such as boxee box rouko etc ... or software like tversity etc..
BTW Apple Tv2 has a Jail Break (legal) that has xmbc that you can stream your local files (Movies Photos) through the Apple Tv2 device. I haven't tried yet but if I do I will let you all know how good or bad it works.
post #9506 of 18957
I just bought an Onkyo receiver after about 10 years with a Sony STR-DA2ES. It sounds good and I think its working properly. My problem is I don't like how the Onkyo clicks its relays when disabling the center and rear amps (ie going from a multichannel mode to stereo or back again) and how slow it is to detect a dolby digital signal (ie after fast forwarding the dvr, I miss a few seconds of audio when the show resumes). The Sony was nearly instantaneous in finding a dolby signal when set to AFD (auto format decode). How do you think a Denon will be in this arena? Do you think it would be worth swapping them out? I had narrowed it to the Onkyo I now have and a Denon, specifically the 2312. I don't like anything Sony is currently making, although I've been happy with their stuff historically. Otherwise, I would just get another one.
Thanks for your input.
post #9507 of 18957
Hi all,
Been lurking here for a while eversince I got my AVR 1612. Tons of useful information here.
Just have a quick question here. I have successfully connected my set top box and confirm that I am able to receive the 5.1 broadcast from my Set Top Box HD channel. Currently for the program that broadcast in 5.1, I am watching it with Dolby Pro Logic surround mode in my AVR 1612.
If I am understanding this correctly (sorry a total newbie here), Dolby Pro Logic is used to simulate surround sound from a stereo broadcast. So if this is correct, do I mess up the 5.1 sound from my Set Top Box by setting it to Dolby Pro Logic in my AVR ?? Is there anyway I can hear the 5.1 broadcast as is from my Set Top Box.* I read in one of BatPig post that I need to hit the Standard or STD button in my AVR remote in order to do this. But my AVR remote doesn't seem to have that button. I have tried the Direct button but doesn't seems to work.
Anyone can enlight me with this ????
post #9508 of 18957
The Standard (STD) button is not used on the XX12 AVR remotes, rather you'll want to press the MOVIE button and select DD PLII when a SD channel is playing to simulate 5.1 while a DD 5.1 will play as DD 5.1, although note that not all stations will broadcast a DD 5.1 audio track even though the show is advertised as being in DD 5.1.
post #9509 of 18957
Saj2001ind, Kalani and Spager - thanks for your advice. You have simplified my problem and saved me a ton of time. I am now going to look into the various media servers
post #9510 of 18957
Thanks smoothie,
Another questions, if a HD 5.1 channel is in deed broadcast from my Set top box while the surround mode in the AVR is set to DD PL II, will the 5.1 override the Dd PL II setting in AVR or will the 5.1 signal be altered in some way by the surround mode.
thanks for the patience. I am total newbie here. might don,t know exactly what I am talking about.
