AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 324
post #9691 of 17929
^ So Pandora won't show up on screen digital...is that what you mean?
How about setting the AVR to NOT change or add your any changes to your tv picture settings? Cause when I look at the video status,it says movie.
post #9692 of 17929
Thinking of adding an amp. I have a 2312ci. Anyone recommend an amp that will match up for fronts? Thanks
post #9693 of 17929
good thing you are only thinking about it, because the 2312 doesn't have pre-outs...
you'd have to use a speaker level to line level converter in order to add an amp...
you going into protection and/or clipping? if not, don't bother...
post #9694 of 17929
Hi, I'm thinking of upgrading from my AVR-1909 to one of the newer models as I will need 3d capability with my new Sony VW95ES projector. So, obviously the AVR-1912 is the direct equivalent today. Obviously this has more features than my present receiver, but would I notice any improvement in the sound itself? I also have the option of upgrading to an AVR-2312 - which is also at a great price right now. This has a few more features than the AVR-1912 but will the AVR-2312 receiver actually ultimately sound any better? And am I any better off still with the Denon over say an equivalent Onkyo? Movie watching is my main priority.
FYI, I have a BK XLS200 sub, Teufel Ultra 2 certified dipole surrounds, Wharfedale Diamond 8.3 floorstanders, Wharfedale Diamond 8.1 centre and Wharfedale Diamond 7.1 rear surrounds. It's my plan to gradually upgrade from the Wharfedales to matching Teufels.
I appreciate your advice.
post #9695 of 17929
Originally Posted by johnwjames5 View Post
Not that I seem to understand a lot else about this device, but before taking it to an authorized service center today, I decided to just poke on things one more time. Letting the unit sit for a couple of days seems to have changed something, and today the unit responds to commands from the remote. Rather than go through and set everything up again, I thought maybe I'd try reloading the config.dat file I'd saved a day before everything went to hell. One thing that is not clear from the instructions or anyplace I can seemingly find is whether or not the unit should be on or in standby mode when I use the web feature to start reloading the configuration. I ask because I've selected my config.dat file, and said to upload, but it's been sitting for 15 minutes or so, and there is no "Loading" on the front display, so I'm not sure anything is really happening. It's not uncommon for the Denon instructions to be vague, so I don't know if I should have had the unit on to see "Loading" or if the process is really taking place, and I'd rather not stop it if I'm just a minute or so from finishing.
Any general clues on this? Should I have started with the unit on or in standby? Does it just miraculously finish without feedback sometimes? I did try to crawl the thread some before posting this, but I just wasn't finding a hit, nor was I able to find anything starting from Google and pointing into the forum. Thanks.
I would rerun Audyssey if it doesn't work and their is an issue get it repaired and be done with it. If it works, problem solved and move forward. After you rerun Audyssey save a fresh Settings and get rid of the old config.
Yes when you save and load leave amp on. It will shut down and restart by itself.
post #9696 of 17929
If you can get the 2312, buy it as it has a better Audessey bersion than the 1912. You can also get the 2112 for $450 which has Audessey MultiXT like the 2312.
post #9697 of 17929
I see you are from the Uk and the avr 1912 in Europe include Audyssey MultiXT which will improve SQ. Check pg. 1 of this forum for difference in features and also there is an avs Europe 1912 forum as well.
As far as any other brand I have checked other forums and I quite pleased that I went with Denon.
post #9698 of 17929
Originally Posted by Newb617 View Post
I have my cable box connected to the AVR by both HDMI and red/green/blue component cables so that I can use video select to run the cable TV image to my TV (Samsung UN55D6050) via HDMI from the Denon while listening to Airplay music. This worked without a hitch until I moved last month and had to set everything up again.
Now when I attempt to watch the cable TV signal while running Airplay I get the following warning:
"Your display is not authorized to receive High Value HD content over the digital link. Please use the YPbPr outputs for your HD connection."
The picture appears on my display, but it's wavy. The obvious question is: what changed? The only difference in the chain is a new cable box. Comcast made me turn in a DCX model for a newer RNG200N HD-DVR box. This strikes me as the most likely source of issue, but I'm not sure. The physical relationships of the wires and components are also slightly different, as the coax cables and R/G/B wires now have to course by my power strip and Jamo S606 speaker towers.
Troubleshooting so far: I double checked all connections, and they're fine. Firmware updates for my TV and AVR made no difference. Cycling the cable box provided a temporary fix, but the warning and wavy image returned. I tried changing the cable box output to native rather than its default 1080p. This also made no difference. Isolating the component cables from my speakers and the rest of my wiring did not improve the image.
Any ideas on what is causing this new fault?
Any thoughts out there?
post #9699 of 17929
Got a Denon 2112 a few days ago
try to set it up today (I only have the front speakers now, others on the way) and can't get any sound from the receiver.
Tried different setting, PS3 with HDMI, iPhone through USB, no luck. No sound from the speakers even in the guided setup's speaker calibration step. (Are there any other basic mode that I can test the receiver with?)
The speakers work great with my old Pioneer, so I just want to know if there are any other ways I can test the receiver with before I return it or call the local repair shop
post #9700 of 17929
Try assigning the component from cable box to a different source on the avr that you are not using like for ex. V. AUX and then in Net/USB .. Video Select ..select V. AUX and see if that makes a difference.
post #9701 of 17929
In the Auto Setup/Amp Assign select 2 CH and if you don't here any chirps when you run through auto setup make sure you have the speaker wires hooked up to the front R/L speaker terminals on the avr. If no luck try a Microprocessor reset check pg. 1 link 5 for how to reset.
post #9702 of 17929
Originally Posted by candy76man View Post
I recently got a refurb denon 1912 (to replace my onkyo606 due to the hdmi daughter board failing) and am very happy with it except for one annoyance.... The volume control..... If I hold down the volume button it goes up or down way to fast and always overshoots the volume level I want by a good margin, but hitting the volume button repeatedly to go one notch at a time is way too slow. I am using a harmony one remote but the volume "speed" is the same when using the factory remote.
Has anyone else noticed this? Is there anyway to change it aside from denon possibly doing something about it in a firmware update?
thanks!
If you are exceeding the volume by a lot you can set the volume Limit to 0 to -20 so you do not to get blasted out of your chair or damage your speakers. I leave mine at 0.
post #9703 of 17929
I set the limit ( I have a 1 year old that loves remotes) but that brings up another question...what is the deal with the absolute and relative volume options? Why would I want my volume to start in the negatives and go from there? That just seems needlessly confusing?
post #9704 of 17929
Sorry if this has been answered elsewhere, but I haven't found a clear answer to this question. I currently have a PC connected to my Dell U2410 via HDMI at a resolution of 1920x1200.
If I connected that PC to one of the Denon xx12 receivers, probably a 1912, and then connected the receiver to the U2410, would I still be able to display a 1920x1200 resolution?
post #9705 of 17929
Anyone know if its possible to get this thing to NOT output a blank signal on the output HDMI, when the selected input is OFF? (model 1712 in my case)
My problem is, kids turn the Xbox off, forget to turn the AVR off, and it sits there with a blank signal... enough to keep the projector thinkng it needs to be ON, but appers to the kids that its off. VERY annoying. Why have a live signal out when the blasted input is off?
post #9706 of 17929
Thanks. Unfortunately the 2112 isn't available in the UK. So it's either the 1912 or 2312 for me. Just need to work out whether the extra features on the 2312 are worth the extra money, i.e. at the end of the day does the 2312 deliver a better sound or is it basically a 1912 with some extra bells?
post #9707 of 17929
Originally Posted by dkushner View Post
I happen to be the software testing manager for a software company and have significant troubleshooting experience in general so maybe I'm sensitive to defects and unreliable behavior. This is my first Denon purchase and overall I'm disappointed with Denon's quality control. Many companies lack in this area and I was hoping a brand like Denon would be better than what I've personally experienced.
I also work for a software company, and have had the same experience with my AVR-2112CI. We would never let a product ship in this condition to a customer. Has a manager or executive even used this thing to play a song from a media server?
YES, and still drives me nuts! If you hold down the button for a slightly shorter period, you get 0.5dB movement. If you hold it down a hair longer, you'll get an unpredictable 5 to 8dB movement. Sometimes I keep trying to repeatedly hold it down the magic amount to get it to do what. Other times I give up, and it's tap tap tap tap...
Truth be told, this might be the #1 thing (aside from the poor NET/USB interface) that drives me to replace it with something from another manufacturer. Folks will tell you that "you get used to it," but you shouldn't ever have to "get used" to anything. Plus, it's been several months and I'm still not used to it.
I don't know why Denon didn't implement a simple acceleration mechanism like other vendors have done, or at least allow us to customize the parameters in the setup menu.
I never had to think about how the volume control worked on my Yamaha or Pioneer. It just worked.
post #9708 of 17929
When using the "Relative" volume scale, the "reference" level setting (used in films) is set to 0db which is easier to remember. Some prefer the "Absolute" scale which is all positive numbers, but then reference volume is 81. As with the case of the various listening modes, use whichever you prefer.
post #9709 of 17929
Not likely no ... generally only standard TV resolutions work correctly.
post #9710 of 17929
Sounds like you would benefit from a Harmony (or other universal) remote that works based on "activities" ... you turn the activity OFF and it turns all the devices in that activity OFF.
post #9711 of 17929
As spager noted, the EU 1912 has MultEQ XT which is likely why there is no 2112 ... and no, the 2312 won't have better sound, rather only extra bells (eg. video chip, GUI overlay on 3D video).
post #9712 of 17929
2312 has an extra optical and an extra cinch digital input compared to the 1912.
post #9713 of 17929
I knew I should have got the 3312! I thought there might be other connections you could do. Thanks for the feedback. I guess this means I have a new Marantz or Denon in my near future!
post #9714 of 17929
The benefit of the Marantz models, is that even the lower level models offer at a minimum the FL/FR preouts.
post #9715 of 17929
If you are still in your 30 day period take/send it back and pick up what you need/like.
post #9716 of 17929
or buy the 3312 as the main amp and use the 2312 as the second amp.
post #9717 of 17929
It seems my colors are off on my PS3 is why I need to know this...unless its something else?
Also what should the chroma level be set to?
post #9718 of 17929
Waste of money, considering the prices. Better to sell the 2312 (assuming it's too late to return) and put that money towards a dedicated amp, like the Emotiva 3 or 5 channel amps, to use with a 3312.
post #9719 of 17929
Hey guys I have the 3312 and currently running 8 years old pols audio 5.1 packaged system speakers. Looking to upgrade to tower speakers soon...any recommendations?
post #9720 of 17929
head to the speaker forum and post your budget, room size, etc. Not really on-topic in this thread and you will cast a wider net for help there.
