I am proud to say I have started the process to build my dream sub! Here are the preliminary specs...
TC Sounds Custom Pro 18" Driver (Ferrite Magnet)
Dual TC Sounds 18" VMP Passive Radiators each with 2200 grams of mass
9.042 Cubic Foot Box tuned to 16.03Hz (25x25x25 Internal Dimensions, double thick 1.5" baffles for the driver and passives)
I was originally planning on using a Pro 5100 driver and doing a 7 cubic foot box, but came across a DEAL on 2 Custom subs, so I jumped on it. I also bumped the box to 9 cubic feet. The short of it is that the subs are a Pro 5100 top assembly with a Ferrite Motor instead of Neodymium.
Attached are the WinISD files. I have one with less moving mass on the passives... Still trying to decide, but that is the beauty I can play with it! These were done with the Pro 5100 driver but I will be updating these files with the specs of the Custom subs soon.
Let me know what you guys think of my plan and any insight would be great.
Don
Don
TC Sounds Pro 5100 with Dual TC Sounds 18 VMP - 7 Cubic Feet.zip 2.4677734375k . file
It is very heavily braced and has dual speakons so I can daisy chain the 2 subs later if I want to, or I can just run a dedicated wire to each, at least with 2, I have the option.
I guess I will just have to be content with building the sealed sub this weekend and the ported subs next weekend....
