AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Receiver Help for 7.1
post #1 of 22
Hey all,
This may be a question you get all the time and if there is some thread covering this already. But i'm looking to do a 7.1 set up with a undecided speaker line up but will be in the $1300 to $2000 range for all speakers. And would like to have 2 subs going as well.
From what i understand, all i need is a AVR that can deliver the surround processing and some decent amount of amp, But i don't know what the difference of a $1000 AVR from a $2000 AVR. Right now all i know to look for is the highest level in surround processing and that's about it. I know there's more i'm missing. Can anyone explain this or point me in the right direction?
Pete
post #2 of 22
Is the receiver strictly for movies, tv, gaming...any music. Size of room...do you care about audyssey and other calibration methods? What are you connecting to the receiver? Do you need networking? Do you need more zones? What speakers have you been looking at? It would be easier if you told us what you wanted in a receiver feature wise and gave a price range. Then we can make suggestions and you can compare them and see which will work best for you.
post #3 of 22
Ahh forgot to mention that stuff...
The theater is 60% movies 25% TV and 15% gaming.
The room size is 15' wide and 28' long (seating at 12' and 18')
Would love and calibration (I've read some reviews of the calibration not sounding that great though so not sure about it completely).
Speakers: I have no idea and not commited to anything (i do have a def tech 12" sub though).
Not sure what i need in a receiver but i would like one with a great set up menu on screen(i would also like anything that helps the surround processing of music and movies) I'm looking to spend $800 to $1500. Would consider a $2000 if it's amazing...
post #4 of 22
imo/ime, it would be better to resolve this first, then decide on electronics...
what's your "total budget" for everything?
post #5 of 22
x2 it would be good to know that you might want to buy some 4ohm speakers or speakers which require and external amp first
Additionally spend 1/3 on receiver and 2/3 on speakers
post #6 of 22
yup... although in reality, in the average home setting*, there's not too many speakers out there that can't be driven with a run of the mill avr... seems to me that the great majority of people who post never go past -20db on the avr... even with 4 ohm speakers, that wouldn't be a problem for anything that's not a total pos...
at least 2/3rds on speakers... there's a lot of really decent 500 dollar avr's out there in today's world... given that he was prepared to spend 2k on the avr, that's 1500 that could go to the speaker/sub budget...
*note that "average home setting" doesn't describe some avs members...
post #7 of 22
Speakers should be your first priority and you should spend the most on them. The technology really has not changed much and what sounds good today will continue to sound good In 5 years.
I would look qt floor standard for your main speakers,
Look at focal, paradigm, def tech, b&w. For your subs look at some Internet direct companies like hsu and svs. They offer the best bang for buck. Start with 1 And move up to dials. In a room that size your probably going to need duals.
For your original question...go to www.audyssey.com and look at the audyssey products and check the boxes with multeq xt and multeq xt 32. This should give you plenty of options in your price range from a large group of manufacturers all with the latest calibration software. Almost every receiver with those two functions will be 7.1 or 7.2 ready if not 9.2.
post #8 of 22
fwiw, id speaker manufacturers offer the best bang for the buck as well, that's not unique to subs...
edit: and without knowing his listening levels, it's hard to make any speaker recommendations at all... if he falls into the aforementioned "-20db" category, that's one thing... however, if he's trying to push to reference in a room that size, he's going to be looking at completely different speakers...
post #9 of 22
Speakers are something that I like to hear in person before I buy. I have no doubt that ID speakers are great but it's hard to push the button w/out hearing. I also like to be able to demo the speakers in my room which both my local stores allow me to do with no questions.
post #10 of 22
ID speakers are different that subwoofers in my opinion
And many ID companies like Aperion to name one have a 30day in home trial period. Cause hearing speakers in a sound test room of the hi-fi store is different than hearing the speakers in your own room
post #11 of 22
Awsome guys,
Very helpful! Sounds like you answered my question in a way as well. The AVR are not the bottleneck in the sound chain and the speakers are. So i like the idea of shifting budget money out of AVR and into speakers. As far as my listening levels... I'm more the -20 dB i think. Maybe i'll probably go a bit louder when i get to listen to concerts on blueray.
My total budget for everything (pj/screen/speakers/AVR/chairs/ect.) is $10K to $15K with $4K to $6K going towards the pj/screen combo.
I'm 90% sure I don't want to venture into seperate amps to pair with the AVR. Seems like you get a lot more volume that I may not use too much.
Thanks a lot you guys are a great help.
post #12 of 22
Also to note... I'm putting bass traps in all 4 corners and a rear diffuser and will see what early reflections are needed after the build is done.
I hope this enhances whatever speakers i buy.
post #13 of 22
Another question: If i want to use 2 subs, a) do i need a X.2 receiver or b)it's best to have an x.2 receiver but there is a work around with a x.1 receiver.
post #14 of 22
No you don't need a x.2 receiver as you can get a splitter and just use that
Have you gone to an audio store yet and listened to different speakers?
Generally you can get a better deal online but its better not to puchase speakers with "blind" ears. Subwoofers on the other hand are a different story
post #15 of 22
Not yet.. need to go visit... soon... but mainly doing research to be prepared to what i want to save for/spend.
I do like the the idea of buying online for the sub.
Also looks like the top of the line Onkyo is loaded with features. Are they any good? or is Denon a better made AVR (same price with less features).
Edit: Onkyo have more better models than i originally saw.
post #16 of 22
You can easily use a Y cable to split the subwoofer pre-out. However, any receiver that's going to fill your theatre, with something left over for headroom, will probably already have .2 on the subs.
You're already considering two subs. That tells me you have a preconceived notion of the sound levels you want, and the levels are not that lightweight. Take a look at the Denon 4311 AVR, the Onkyo TX-NR5008 and the Yamaha RX-A3000. And start auditioning speakers. Your ear will know what it likes.
Welcome to the addiction, ah, I mean, welcome to the hobby of home theatre.
Edit: All three of the receivers listed above have pre-outs available for all channels. So....if you decide you want more juice later, just add an amp or 2. Or 3. Or...
post #17 of 22
Actually From what i understand, and i could be wrong, having 2 subs can improve the quality of the low end sound as well as the volume of it. I'm aiming more for the quality.
This is all based on theory.
4 years ago I had a one room condo/loft that was horrible for sound and the past 4 years i've been doing dvd's on computer and xbox with a 20 year old jam box with some nasty nasty speakers with cobwebs in them as the sound source...
So needless to say.. anything will be a giant upgrade...
post #18 of 22
good man! and yes, it sure will...
your understanding is correct...
you have a nice budget to work with... you should be able to get yourself something that will work very well...
now you just have to figure out what "that something" is...
haunt the speaker sub forum for awhile... try and get out and listen to some speakers... if you want to hear some ID speakers, post in the owner's thread, you can usually find someone who is more than willing to demo theirs for you....
and have fun with it...
post #19 of 22
Two subs, properly located and eq'd, is a huge step up from a single sub. Absolutely the way to go. Just keep in mind that that's a fairly large room. An AVR will be just fine, if you don't go too light. The AVRs I mentioned before should be $1500-1700 depending on the deal you get.
Don't let a salesman push you into separates, just so he can earn a larger commission. They'll hear the phrase "home theater", and the dollar signs will light up their eyes.
Trust your gut. Put the rest of the money into speakers. They dictate the sound more than anything else.
Oh, and, run conduit for your cables, so you can snake replacements in later. You won't regret it.
post #20 of 22
Find a dealer that sells Integra. No, I am not "recommending an Integra"...but any mom/pop shop that sells Integra will know what they are doing.
Most shops that sell Integra also sell (in variation) Marantz/Elite/Denon/Yamaha.
post #21 of 22
2nd the Integra idea
post #22 of 22
Ahhh... all very helpful people in this side of the forum... you guys should all go hang out and cheer up the dedicated home theater construction room. I'll definately look into the integra supplied stores.
there is so much to know, I can understand why the home theater store guys should get paid. To get a grip on all this info can take a lot of time and desire or need for a paycheck. I have found one, I think, that seems pretty DIY friendly (ie, they don't want to sell me the whole package but will sell what I need), but their showroom is A room, nothing else.
Thanks a bunch
Pete
