Originally Posted by darinp2
For reflected light from the screen the HCHP should be one of the best screens around for maintaining ANSI CR in a light colored room when sitting in a good viewing position for it, since the screen has both directionality and a gray layer to help reject those reflections when they come back to the screen.
--Darin
--Darin
I would, though, caution persons to check out the HCHP with samples from Dalite to verify that its very narrow viewing cone doesn't lead to brightness variation from their viewing position. Even though I have basically just one viewing position, since I sit rather close (1.0 SW) to a large screen, my RS20 has to be ~ 4-5 ft behind my head (so that I can do the zoom method for 2.35, going to a 144"W pic).
In my case, the samples of HCHP showed brightness fall off at the left and right edges of the screen; maybe not noticeable on viewing real material, but it was definitely noticeable with a white screen. The HP2.4, though, was perfectly uniform in brightness (due to its somewhat wider viewing cone). Also, since I have black absorbing material on the ceiling and side walls (out ~8ft from the screen wall), I am not concerned with the more side wall reflected light the HP2.4 might have over the HCHP.
) once i lower the projector to the correct level...
