Originally Posted by Lawguy
True. Small samples only tell you a little bit.
You may also want to check out the Firehawk. It is higher gain and also would probably improved on screen contrast over the HP. One thing that I realized is that although the HP was very bright, it was probably too bright for my 106" screen and, as I mentioned, resulted in image harming reflections. The .8 BD is much dimmer but I really don't miss the brightness because the picture is much better overall.
It's interesting the effects of different screens, isn't it?
When I had my HP (2.8 gain) screen up and was comparing it to essentially a neutral gain white screen, the trade offs ebbed and flowed with program material. (This was even before my room was well treated for reflections, as it is now).
The added brightness of the HP screen made for a perceptually sharper, more dimensional image particularly on brighter scenes without too much dark area (the more dark the image, the grayer and less dimensional the image on the HP screen appeared). Darker scenes looked more convincing on the lower gain screen, due to the dimmer picture.
Overall the neutral gain screen never quite reached the heights of "wow" of the HP screen on certain scenes. But there was an overall sense of solidity to the image, anchored it seemed by the deeper black levels, that made for a more consistent satisfaction for me. That was true even as I envied what the HP could do with lots of scenes. (That's skipping my issues with viewing angles as well).
So, always a trade off.
But as long as you don't need a really big image, it seems you've got a bright enough image on the BD screen, while benefiting from the deeper black levels and better preservation of contrast, which sounds like quite a good trade off.
) So, some difference from seat to seat could be an acceptable compromise IF the light rejection properties of the screen improve image quality overall.
