Originally Posted by Hughman
No question, sitting at 11 feet from any size screen will put the adjacent side seating greater than 10 degrees off axis and closer to 15 and that's where the gain drops quickly. My photos in my first post and impressions were gathered sitting with my eyes about 15.5 feet from the screen which keeps the viewing cone from three seats within about a 20 degree cone (10 degrees off axis each side.) When I find myself swaying back forth while watching movies it's time to put the bottle down and head to bed.
I was between 10 and 11.5 feet from my HP screen. (105" diag). I didn't need to be boozing to see the brightness shifts. I was sitting on a normal, single person chair. My back can get sore if I stay in the exact same position for long periods of time. So I'd go from leaning on side of the chair arm and after a while shift and lean on the other side. I guess this would move my head a couple of feet or so, but I could always see the image brightness shift every time. Drove me a bit nuts. I have a to-the-inch 3D computer model used to design my theater room and I took the measured/stated viewing angles of the 2.8 HP screen and plotted them to my room, measuring degrees of viewing angle from my seats. It turns out it was entirely predictable I would be able to perceive changes in brightness even with such relatively small moves. (I think the brightness change was something like a 20 percent drop when I'd shift my head).
As usual...sensitivity to these things vary....(I can only imagine my reaction to the even narrower cone of the new gray version).
Most people don't see the texture on the HP screen either. I found the HP screen generally very clean looking and only occasionally thought I spotted some texture, whereas I believe you found it more objectionable.
