Originally Posted by
borland
Madagascar works fine on my BDP-140 with 4.03. Probably problem with ISO. Check the source (I have no clue where you got it from
, but if you have the original BD - rip it with ANY DVDHD to ISO and check again). DTS HD Mstr works fine. What audio output settings you did set for BD ISO? PCM or bistream?
Not sure about subs but external subs I think should be in unicode.
Thanks for your reply.
-Subtitle issue is solved. I just saved the .srt subtitle wih "Unicode" encoding. And all special characters are visible now. And subtile appears fantastic. Decrease/increase size, changing color and location is possible also. It's beyond my expectations.
-"Madagascar 3 : Europe's Most Wanted 3D Bluray.iso" release is the only one not working. It was HD-China release I suppose. It was working ok with my 3D media player Himedia 900a. Anyway, no big deal. It's just 1 movie.
-To avoid any misunderstanding, HD audio with Blu-ray .iso s are working good. All audio is set to Bitstream. BDP-140 transmits the the HD audio lossless and DTS-HD MSTR or Dolby Tru HD signs appear on my Pioneer 920 AVR.
However, if I play .mkv file, there's no audio when the movie's audio is DTS-HD Mstr.
Simply, HD audio is OK for BLU-RAY. But there's no sound when it's .MKV
I'd like to ask one more thing. When I put a BLU-RAY Disk to BDP-140, is there any chance to apply/choose a external subtitle from a USB drive? B
