Originally Posted by mixolydian12
So after a 3 month relationship with this TV, Toshiba is taking it back and replacing it with a 47L7200u.
The bezel of the tv popped off, and it suffered from an annoying flicker that seems like a fairly widespread problem. Since the bezel was back-ordered for 3 months, Toshiba agreed to replace the TV with either a refurbished 47TL515u or the new 47L7200u. I opted for the new model even though I couldn't find a lot of reviews because the flicker problem sounds as if it won't be resolved by Toshiba.
I hope the new model has less problems.
That sucks. How is the world did the bezel just pop off? were you moving it or something?
SO I'm curios as to what everyonje is talkig about in regards to the "Flickering" issue... What is it and when does it typically happen?
