Originally Posted by sanderdvd
Ok. Another question:
Is there a way to remux a 3D .iso to a smaller 3D .iso (max 25gb)? I ask this because with 2D .iso you can 'extraxt' only the main movie with tsmuxer to the end result is a max 25gb file WITHOUT any re-encoding done (no quality loss). Would like to know if this is possible for a 3D .iso (so I can use 25Gb discs to burn on instead of the much more expensive Dual-Layer discs)
An alternative sander [to shrink the iso files so they will fit on a bd25] is fabs bd copy which will convert to a sbs iso file with imgburn . This can be burned or left as a file
If you have a good upscaler it is very close to a full iso quality . You can make this a main movie iso or a full disc version atm . If you burn it another advantage is its theoretically compatible with a 2d bluray player as its still 1080p/24
Maybe try the free trial to see if it meets your approval ; the latest firmware lets you mount a mini iso [nice small file] as a bd folder on your computer as a bd50 using dvdfab virtual drive . Ive not tried it myself as I use a oppo 95 with iso [frozen in time
]Quote:
New: Added support to copy Blu-ray 3D disc/iso to Blu-ray 3D folder using "Copy [b]as Blu-ray 3D".
] any shrinking me likey
