Originally Posted by erik71
The WH12LS30 is NOT on the MCSE list:
http://ala42.cdfreaks.com/MCSE/
WH10LS30 is on the list (I have one and have unlocked it with MCSE). Also, I see that BH12NS30 is on the list, but I have no idea if you can cross-flash that onto the WH12LS30, unlocked or not.
This guy was able to unlock a BH12LS35, which is not on the MCSE list, so maybe the WH12LS30 could be unlocked with MCSE. Note the speed comparison at the end of the post -- the fastest BD rippers were a Sony and a Lite-On (without need to unlock).
http://blog.insanegenius.com/2011/04...ollection.html
If you are feeling adventurous, you could download this BH12LS30 firmware, unlock it with MCSE, and flash it. I'm not sure I'd risk it, though.
http://files.rpc1.org/index.php?act=view&id=5864
Alternatively, you could dump your firmware with a program called "flasher", unlock it, and flash it:
http://forum.rpc1.org/viewtopic.php?...st=0&sk=t&sd=a
So maybe you ought to talk some sense into me.
I downloaded the firmware version using the link you gave me. I also checked out the mymce forums and other blogs and the firmware seems correct. I also dumped my drive's firmware and it looks very similar to the downloaded firmware version using MCSE, although not exactly the same.
I edited the speed using MCSE and now am sitting on the firmware. Part of me is thinking, why do I need increased speed? Half the time I'm not here even if the speed were faster. I mean if I set the ripping process to start when I go to bed (as I frequently do) then what does it matter if it takes 1/2 hour or 2 hours? The other half is thinking, do I care about the noise of the drive? Can I flash it back if I need to? And one last part of me just wants to do it to prove to myself I can do it....But that's one heck of a gamble with a $99 drive.
