Hi,
Does anybody have any experience with the Wesena Cases? I'm looking to build a i3 HTPC. I was thinking HDD, 4GB RAM, and an internal Bluray. Maybe a SSD for the OS if you guys think its worth it.
Should I go 2100t or 2100?
I would like to:
1. Watch 1080p.
2. Play Bluray discs on an internal drive.
3. Use as DVR with either ceton infinitv4 or HDhomerun prime when it comes out.
4. Streaming online 1080p from the interweb.
5. No gaming.
The case should be as small and pretty as possible to overcome the "wife barrier". So I figured the Wesena is perfect, but i couldn't find any reviews for it. Which is the smallest Wesena case that will fit my build.
I read somewhere that the cases have a problem with the Bluray drive eject button, it being on the wrong side or something. Is this a rumor?
I would like to:
1. Watch 1080p.
5. No gaming.
