Or I guess I should say quick "passive bi-amping" question.
I still don't quite get the logic into why it doesn't work.
If a 7.1 receiver, which lets say its rated at 100w per channel, takes the extra "surr. back" channels and pumps them into the fronts, why wouldn't that add a little more power to the fronts?
Your whole argument that it would not add power, is solely based on the argument that if you do not have speakers connected to those "back surr. channels" then the receiver is putting that extra power in the 5.1 channels that ARE connected.
But after looking at receiver manual after receiver manual, I don't see where it says that it takes the power to the "back surr. channels" and Pumps that extra power to the connected 5.1 channels, if the back surr. channels are not being used.
So are you saying that if a rated 100w per channel 7.1 receiver is only hooked up to a 5.1 channel setup your actually getting more power to each of the 5.1 speakers than its rated at when its outputting its maximum power.
