AVS › AVS Forum › Video Components › Home Theater Computers › HTPC spec look ok?
HTPC spec look ok?
post #1 of 14
I was planning on re-using the guts of my current Q6700 machine for my HTPC and building a new PC to be my primary tower. However, since my current board won't support both the Hauppauge and another video card (only one PCI-E slot) it means I'd have to buy another motherboard.
This has led me down the path of wanting to buy only what I need to build the HTPC (I have some components already) which would be a considerably cheaper route.
My aims with this system are mainly just as a PC connected to the TV to surf and play online videos, and to capture in HD from my cable HD-PVR via component.
See what you think about this spec, I'd be grateful for some feedback.
Mobo - BIOSTAR H61MU3 LGA 1155 Intel H61 (LGA1155, max 8GB RAM)
CPU - Intel Core i3-2100 Sandy Bridge 3.1GHz
RAM - G.SKILL Value Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) - (One module, so I can double up later if I need it)
Capture - Hauppauge Colossus PCI-E capture card
Video - GIGABYTE GV-N210OC-512I GeForce 210 512MB 64-bit GDDR2 PCI Express 2.0 x16 HDCP Ready
Case - Thermaltake V3 Black Edition
Total $472 delivered from Newegg.com
I already have:
Thermaltake 600w PSU
Black SATA DVDRW drive (can upgrade to BD drive later)
2TB hard drive
All the cables I need
Wireless keyboard with touchpad
Windows 7 Pro x64
I like that the mobo has two PCI slots in between the PCI-E 16x and 1x slots so this should allow for decent cooling.
I was told in another thread that with the Hauppauge Colossus you still need a video card as well, so I included one above. But if that's the case can anyone tell me why the Colossus has an HDMI output if it's not able to be used as the system's primary video output card?
post #2 of 14
With that CPU, if you get an H67 motherboard you won't need a seperate video card.
post #3 of 14
How do I get HDMI output though? I've looked at some boards and a lot of them don't have HDMI output on-board.
I presume the idea is that the on-CPU video technology is supposed to output to an on-board output connector?
post #4 of 14
Correct, with an H67 or Z68 based motherboard.
post #5 of 14
Great!
So now my parts list is:
Mobo - MSI H67MA-E35 (B3) LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
$457 delivered
Any other recommendations?
Also, does anyone have any comments on the capture software that comes with the Colossus? Or is other software better.
post #6 of 14
Why would the H61 require a separate video card?
post #7 of 14
There's a great thread here on the Colossus. It will give you lots of good info.
And I suggest looking at renethx and assassins guides at the top of the forum index for great hardware recommendations.
post #8 of 14
Do H61 cards support HD2000 Sandy Bridge graphics? Sorry, if my understanding that one needed an H67 or Z68 was incorrect.
post #9 of 14
Only the oddly-positioned P67 lacks the video output. Take a look at any H61 board and it should have a bevy of video output ports. This is not to dissuade anyone from springing for the H67 if they want its features, just video isn't one of them...
post #10 of 14
I already have:
2TB hard drive
Windows 7 Pro x64
Personally I would wait for Llano reviews to start coming in. Both Sandy Bridge and Llano should be able to do what you are talking about without the graphics card and no need for 700w psu. I also would buy a 2X2gig ram kit as you will want the speed of dual channel. For HTPC you do not need more than 4gigs.
post #11 of 14
What are the H61-H67 differences? I thought I needed an H67 but maybe I don't. Thanks
post #12 of 14
Per http://en.wikipedia.org/wiki/LGA_1155, which is easier to find than the Intel site but shows the same information I remember, it's:
no raid
fewer USB 2.0 ports
no SATA 3 (so only 4 SATA unless the manufacturer includes a separate controller)
fewer PCIe lanes
2 vs 4 memory slots
From my perspective, for an HTPC these things are unnecessary. I won't be using an SSD fast enough to justify looking for SATA3, 10 USB ports is more than twice what I'll be using, I'll be starting with 8GB of RAM, and I have a total of two expansion cards planned, and maybe a third if I decide I want a discrete graphics card. Nothing on H67 that is worth paying for, for me. YMMV, of course.
post #13 of 14
The H67 board I listed above is less than $100. I don't see a reason not to buy one at that price.
I found the colossus thread, I will go read it through!
post #14 of 14
You're right - it did.
Looks like that's the way I'm going to go then. For less than a $500 outlay for the remaining parts I need, it looks like a winner.
Once I get it set up I might sell my almost new DVD recorder (Magnavox 513) since I will likely have no use for it. I wish I'd just gone the HTPC route in the first place now.
