Originally Posted by gsr
Did you move the 5124 card to the same slot the 5000 card had been in or leave it in the slot it was in? Unless you moved it to the slot the 5000 card was using, you can't really draw any conclusions that the 5124 card was the problem. A couple of good tests to run would be to put the 5000 card into the slot the 5124 card was in and see what happens and then put the 5124 card into the slot the 5000 card was using and see what happens. My hunch is you'll find there's something about the slot on that motherboard that's causing the issue (something like an IRQ conflict, for example).
I actually have tried switching and verifying each time. Its something with the two cards in at the same time. I sent CETON a log of each card - Hopefully they can figure it out as I would hate to have to build a new PC.
Your most likely going to need a tuning adapter as well . Those are free at the your cable co.
