Originally Posted by smcmillan2
I was getting "no tuners available" when I brought the HTPC out of sleep, but if I waited a minute or so the problem resolved itself, no reboot necessary. Same specs - USB, 4881, purchased Dec 2011. I still see the same with 1.1.7.2
Since loading 1.1.7.2 last Friday the Ceton has not rebooted on it's own, uptime 6+ days. I shut everything down last night to upgrade the memory in the HTPC so I've reset the timer, but at this point I would recommend loading 1.1.7.2 and see how it works for you. You can always revert back to 1.1.2.4 if it causes other issues and frankly 1.1.2.4 was not very stable on my USB unit.
I did a trouble ticket with ceton for my USB and they recommended a beta fw upgrade, which btw does not have a 1.1.7.2 in the number series. Am holding off installing until next wek as I have some critical recordings to make.
Your most likely going to need a tuning adapter as well . Those are free at the your cable co.
if u are referring to me
