Originally Posted by
The_Nephilim1
Hi, I just bought this and tomorrow the Comcast guy is comming but I think I am not going to get this working..
It says it needs a HDCP TV or Viewing deviceconnected probally by DVI.. Well thing is I have a Projector and it uses a VGA 15 pin connector.. Now my question what channels will work with this kind of plug??
Or will I be totally out of luck and it will NOT work at all?? I did want to get the 3D channels the reason I bought the Cento tuner in the first place Please advise..
Try hooking the machine up via HDMI or other HDCP compliant way to a capable tv or monitor, run the digital cable advisor, then hook it back up to your projector any way you want. You might be able to find a registry setting to change to accomplish the same thing without the work.
I have a machine hooked up to my old 720p LCD in the bedroom. the machine and tv are both HDMI, but @ 1366x768, I cant do 1:1 pixel mapping with that connection without significant work arounds. Therefore, I just use VGA to make everything nice and easy. Anyhow, once DCA was run and checked good via HDMI, I switched right back to VGA connection and have no HDCP issues at all. You probably could accomplish similar.
