I'm using an InfiniTV 4 PCIe and I'm having problems getting all four tuners to work.
Three of the tuners seems to work fine, but in situations where I need the fourth tuner (such as when I'm recording 3 shows and watching live TV), I receive a "No TV Signal" error message.
I've checked the tuners using the Ceton diagnostic tool and the problem always seems to be related to the same tuner (Tuner 2).
The SNRs and Signal Levels on the three working tuners appear to be fine (36 dB and -10 dBmV, respectively) but the SNR on the malfunctioning tuner is low (20 dB or less).
Since the problem is always related to the same tuner, is it possible that faulty hardware could be the cause?
Sounds seems fine though.
