Originally Posted by elockett
Thanks for the quick replay GSR. A few points and some pondering:
To be sure I understand I what you said about recording to hardrives, if I set up network tuner sharing and assign tuners to clients, then the recordings must occur on those client's local drives correct? This would be OK most of the time but it would be nice to occasionally watch something I recorded in the living room on my bedroom HTPC. I guess this isn't possible without the hacks you mentioned previously.
I'm running a ceton in a WHS 2011 box, with minimal issues, as far as sharing the recordings, for copy freely content, the WHS has an automatic archive utility that will pull recordings from the local machine and place it in the recorded TV share on the server, and then it can be accessed from any PC on the network, for Copy once content, the archive feature still does it's job, but you can only view the program from the PC that made the recording, even though the program will show up for all PC's to see under the recorded TV Section. You'll receive an error message when trying to play from a different PC.
I might suggest for the HTPC, to install the Media Center standby tool, does a good Job keeping your PC in standby, and you can set it to automatically reboot your PC's weekly or daily, Fantastic tool, before using it, none of my PC's would ever stay in standby. With a recording, you PC should wake up a couple of minutes before the scheduled recording time, and then it goes right back to sleep when the recording's done.
The great thing about running ceton in a server, is it's always on, resuming a HTCP from sleep, it takes about 30-45 seconds to get live TV going, That's not to bad.
MY only issue is that I'm trying to be green, but there's something funky with WHS 2011 and the ceton drivers I can't let the server hibernate at night, on resume the tuner basically disappears, you have to reboot the server to get everything working again. With that said, I keep the server running 24X7, but WHS does let the drives spin down while not in use.
