Originally Posted by
giomania
I was also wondering about native resolution output, as I run everything through a Lumagen Radiance, and would prefer the Radiance deinterlace and/or scale the 480i / 720p / 1080i video signals to 1080p. Just to clarify, are you saying there are two possible scenarios, dependent upon the video hardware solution:
1) If you have a dedicate video card, the card will control the resolution and/or scaling settings.
2) If you have on-board video, WMC will control the resolution and/or scaling settings.
Mark
I would like to use whatever is the easiest and most reliable. I'm not opposed to using a dedicated video card, but if the onboard graphics get the job done I'm fine with that too.
I'm not familiar with WMC so I don't know if it has the option to output native resolution and if it did would you need to set up the graphics properties, onboard or dedicated, to allow for the switching of resolution.
I guess ideally the graphics card would allow for the switching of output to 720p, 1080i, 1080p, and 1080p/24. I guess WMC would need to recognize what signal it was receiving and the graphics card would make the switch.
If this is possible I would be interested in knowing how it's done.
